GASOLINE INDICATOR ÇALIŞMIYO HEP LİŞAN YANIYO ..:?
08.05.2020 14:03 # 1
fatih1903
I HAVE A PROBLEM OR I HAVE A PROBLEM IN ITS OWNER, I HAVE A PROBLEM, I HAVE A PROBLEM, I HAVE A PROBLEM, I HAVE A PROBLEM, I HAVE A 307 XR GASOLINE INDICATOR THANK YOU, HAVE A GOOD DAY ..
08.05.2020 14:03 # 2
hasimayaz
In them, the pump and float are combined. It is between 300 - 400 TL in its combined form. If you can find the buoy only, you can buy it for 100 - 150 TL.
08.05.2020 14:03 # 3
peugeotefe
if you come with your car, we will help you solve why it doesn't work
08.05.2020 14:03 # 4
SelmanBeber
my sister 206 caused the same problem several times last summer. We removed the float with a friend who understood, and there was no problem.
then we disabled the battery for another operation, the sieve from the vehicle's battery. the gas gauge improved. Then once again the same problem happened again and again the battery. the indicator was improving when I disconnected the cable and reconnected it. smoothly for the last 8-9 months.
If you want to disable the battery, let's see if it gets better. But let me know the result.
08.05.2020 14:03 # 5
fatih1903
[QUOTE = r3el] my sister 206 caused the same problem several times last summer. We removed the float with a friend who understood, and there was no problem.
alla alla what might have to do with battery electricity, but I was curious about it, I will try it.
08.05.2020 14:03 # 6
SelmanBeber
insha'Allah ..
08.05.2020 14:03 # 7
fatih1903
[QUOTE = AZAZEL] [QUOTE = r3el] my sister 206 caused the same problem several times last summer. We removed the float with a friend who understood, and there was no problem.
good forms, friends, i tried yesterday evening, i removed the poles of the battery. He did not, but the light is still on, it is best to go to a service and get a price.
08.05.2020 14:03 # 8
yes, the guarantee is service ..
08.05.2020 14:03 # 9
HakanGokdemir
I do not know if there is an alarm in your car, but even if it is not from the remote control, press the button to lock your car from the button on the original key, just press it longer than usual, about 30-45 seconds without taking your hand. and after the doors are locked, I would recommend that you do not touch this way for 2-3 hours or even touch longer if possible in the first time. Maybe there is a possibility before going to the service ...
The indicator was falling when I had lpg or 206, and I was resetting the brain with this method because the car thought it consumed gasoline ...
08.05.2020 14:03 # 10
fatih1903
There is no alarm in my car, but I don't mind trying it. Bid before I go, let's try this.
08.05.2020 14:03 # 11
HakanGokdemir
[QUOTE = AZAZEL] There is no alarm in my car, but I don't mind trying it. Bid before I go, let's try this one. Maybe, thank you.
I hope it will happen ... If there is no alarm, I recommend you to do it at night so that it remains until morning ...
hakangokdem is 2009-05-06 10:43:59
08.05.2020 14:03 # 12
HakanGokdemir
Did you try Fatih?
08.05.2020 14:03 # 13
fatih1903
I did not try or I was a little confused last night, but I will try to let you know tonight.
08.05.2020 14:03 # 14
HakanGokdemir
[QUOTE = is hakangokdem]
As I said, since my vehicle is LPG, the indicator needle dropped as if it was burning gasoline, so I found a solution in this way. I taught my friend who works in the authorized service. Big smile
hakangokdem is 2009-05-07 11:40:49
08.05.2020 14:03 # 15
SelmanBeber
Look, I heard that from you.
very interesting :))
08.05.2020 14:03 # 16
hasimayaz
In Fords, the remote control of the key is synchronized when the contact is on and off 5-6 times. :) .. Otherwise, the remote control does not work after the battery is replaced :)
08.05.2020 14:03 # 17
SelmanBeber
I knew it to the master fortress, the connet vehicle of the company I worked with was standing on me.
there are very simple things we do not know that the guys are making money from it :))
We will open the biggest garage of the country.
God come coins.
but I am afraid of what do you know we will have so much money but we will have to disassemble 14-15 key cars until evening :)))))
08.05.2020 14:03 # 18
fatih1903
I haven't tried it or I'll try it again tonight, to the right service on the weekend: ////
08.05.2020 14:03 # 19
HakanGokdemir
[QUOTE = AZAZEL] I haven't tried it, or I will try it again tonight.
If there is a malfunction in one place, it will not be correct if the indicator is not working due to a confusion in the brain. This is just to reset the brain. I hope it will not be a big breakdown ...
