GASOLINE INDICATOR
08.05.2020 21:30 # 1
metin70
Hello friends,
Despite the fact that my car's fuel tank is full, the indicator hand is empty, the light is constantly on and it gives a warning when starting. There is no audible warning when it is in the first place. My location is very hot in the summer. He said it was normal.But since I was a little sensitive, after the last repairman I showed up, the situation I explained above appeared.
08.05.2020 21:30 # 2
BayQ
In cars with lpg, the gas gauge shows like the gas is consuming, the needle falls down.
08.05.2020 21:30 # 3
rolandgarros
In Peugeot vehicles, the gas gauge is directly proportional to the rotation of the wheels. Another term is a system that calculates how much fuel remains during the mileage you covered. For this reason, it is quite normal for your vehicle to light up by treating gasoline because it has a tube in your vehicle. There is no problem. Thumbs Up
12.05.2020 13:05 # 4
metin70
Friends, the repairman who I entrust my car has short-circuited the gasoline float. The indicator is always at zero, and despite the fact that there is 3/4 gas inside, the gasoline warning light is constantly on. The float prices are also very high. What can be done?
13.05.2020 17:21 # 5
[QUOTE = metin70] Friends, the mechanic I entrust my car is short-circuited to the gasoline float. Now the indicator is always at zero and there is 3/4 gas inside, the gasoline warning light is on continuously. Float prices are also very high. What can be done? There is also lpg in the car . [/ QUOTE] Until you fix your situation, you will get on or get off. Meanwhile, if the mechanic did ave he accepted, ask for his money. sonerkyl2020-05-13 17:22:34
06.07.2020 10:22 # 6
metin70
Friends looking for a gasoline buoy. What other vehicles have the petrol float and the pejo 207 1.4 petrol in common?
06.07.2020 10:39 # 7
kaan206
[QUOTE = metin70] Hello friends, Although the gas tank of my vehicle is full, the indicator needle shows empty, the light is constantly on and it gives a warning when starting it. There is no audible warning when looking. My priority place is very hot in summer. Repairers said it was normal in LPG vehicles. But I was a bit sensitive and after the last mechanic I showed, the situation I described above came to light. Does the buoy need to be changed? [/ QUOTE] Lpg does not show that this problem is normal. no. Take out the hour glass, then take out the gasoline needle. Turn your vehicle to the starter position, but if you say it is made to run full, put the gas pointer so that it shows the last line, put the indicator glass in place, turn on the vehicle ignition, let's see what the result is. Or the petrol step motor is defective kaan2062020-07-06 10:41:46
06.07.2020 11:17 # 8
metin70
There is a problem in Şmandıram. It needs to change. That's why I'm looking for a date.
19.10.2020 16:51 # 9
metin70
Hello friends, as I wrote above, my gasoline gauge was always showing empty and was turning on light. I showed it to another master at the weekend The master tightened the socket on the float with a little screwdriver and my gasoline gauge was improved. Other mechanic friends said that the float should definitely be changed. The gasoline gauge turned to normal.
