GASOLINE INDICATOR
08.05.2020 19:30 # 1
ozgorh
Hello friends, the LPG conversion has been done for a few days, but I noticed something, although the car goes to LPG, the fuel needle falls down occasionally, it has caught my attention. Is this normal?
08.05.2020 19:30 # 2
normal coach there is no problem in our vehicles, according to the way you go automatically falls down, the needle will automatically reset itself if you do not drop it below the half tank.
08.05.2020 19:30 # 3
blntctn
I also add that when the tank is full, it will reset when it is half, if the tank is half, it will reset to the bottom of the quarter, usually when the half of the gasoline in it passes, then the needle will be reset :)
08.05.2020 19:30 # 4
ozgorh
So what do I have to do when the gas light is on, it went down under the tank, but the light did not come on, what should I do when the light is on?
08.05.2020 19:30 # 5
you do not need to do anything, make sure that light is on, my teacher, it will be recovered automatically when you start your car because there is half a tank of petrol after enough light is on in your car. But as I said, try not to drop your gasoline under half a tank.
08.05.2020 19:30 # 6
Mesut48
Do not use without gasoline, you burn the pump.
I always keep it on top of the half tank, resetting itself
08.05.2020 19:30 # 7
ozgorh
Doesn't this have any solution?
08.05.2020 19:30 # 8
talip206
[QUOTE = ozgorh] Doesn't this have any solution? [/ QUOTE]
Hodja lpg companies install a kit for 100 lira, but they do not provide a guarantee. If you search the forum, handmade devices are also made. Maybe there are friends who try. Normally, when I get at least 7 liters of gasoline, the needle returns to normal. You do not have to follow or you will either stay on the road or burn the pump because gasoline is low.
08.05.2020 19:30 # 9
ozgorh
Well, does anyone know how this works and how does it work?
