Gasoline Hose
08.05.2020 21:12 # 1
kaan206
Does the gas pipe in the picture go as a whole, that is, to the tank as a whole?
I want to change it so that there is no problem with cracks etc. It goes down the back of the water tank to the tank from there to the back. Has anyone changed this pipe before? How should I proceed? Thanks in advance for your answers ...
1
2
3
kaan206 2019-04-15 18:55:33
08.05.2020 21:12 # 2
Gasoline hoses are not very expensive. The hoses are piecemeal in the engine compartment, and then one piece goes back to the rear.
08.05.2020 21:12 # 3
kaan206
Thank you for your reply.
08.05.2020 21:12 # 4
samet206
The engine looks clean, but the worn out of the hoses is what I fear most. These gasoline hoses are because you do all kinds of maintenance, but they don't come to mind or are delayed.
08.05.2020 21:12 # 5
kaan206
I asked pejo spare parts, I said I'll make it from the tank to the engine.
Can I handle this job with a suitable pipe from the industry?
Has any gas pipe exchangers ever been
08.05.2020 21:12 # 6
You find, hojam, there are OEM gas hoses in the industry. Of course you have to go to a sample piece and look at the appropriate diameter and thickness.
08.05.2020 21:12 # 7
kaan206
Thank you very much for your responses, Soner Bey. kaan206 2019-04-21 11:25:25
08.05.2020 21:12 # 8
You're welcome.What do you mean, we try to help as much as we can.
15.09.2020 18:44 # 9
muzo
Hi my pejo 206 1.4 gasoline I was tired of dealing with this gasoline hose for two years, finally I solved the problem with the R6 28 bar pressure resistant gasoline hose.Video link: https://streamable.com/?src_player=context-powered-byoto53.mp4 - 6.6 MBhttps: //www.dailymotion.com/video/x7w94xq.BIZ? I have cracks etc. I want to change it so that it is not a problem. It goes down the back of the water tank and from there to the tank. Has anyone changed this pipe before? How should I go about it? Thanks in advance for your answers ... [/ QUOTE] muzo2020-09-16 23:20:22
20.09.2020 21:12 # 10
muzo
Hi I changed it.R6 Hose.Peugeot 206 Petrol hose R6 Change oto53https: //www.dailymotion.com/video/x7w94xq1574C1 Peugeot fuel hosehttps: //en.aliexpress.com/item/4001183263154.html? Spm = a2g0s.imconversation. 0.0.66a93e5fgkwc2n & algo_pvid = 1ce69a6 a-4d3b-42b2-a2af-b8129b19e5ec & algo_expid = 1ce69a6 4d3b-42b2-a2af-b8129b19e5ec-a-0 & btsid = 0b01114516005946088391455eaf9 a & ws_ab_test = searchweb0_0, searchweb201602_, searchweb201603_ muzo2020-09-20 21:16:00
13.10.2020 17:17 # 11
kaan206
I went to Kartal pejo and ordered it from france and assembled it myself. It was a figure like 150 TL206 gasoline hose was 3 pieces, the part I changed was 1-1.5m from the gasoline log to the engine flow.
25.12.2023 00:18 # 12
Caqlarozhan
Hello friends, what is the shiny clamped hose next to it? It creates vacuum when I start the car.
