Gasoline Bomb Problem
08.05.2020 20:40 # 1
hakani
Friends, my problem is in the morning work. The vehicle does not start at the first start. When I took it to the mechanic, he said, we need to completely replace the gas pump in the gas tank. The MGA brand will make a figure of 550 TL with the craftsmanship. But some friends said that there could be puncture in the hose. What is your suggestion? And which one would you recommend as a brand? Smile
08.05.2020 20:40 # 2
talip206
My 206 also burned the pump and bought a 75 tlye pump. But if the plastic in which the pump is installed is broken, that is, if there is a gasoline leak, it is necessary to replace it completely. If there is no leakage, it is enough just to buy and replace the engine.
08.05.2020 20:40 # 3
As our friend said, my teacher should only do 150-200 TL max if the engine is broken.
08.05.2020 20:40 # 4
baris1919
I just changed the hose recently, remember that Opel's hose is sleeping.
08.05.2020 20:40 # 5
hakani
Thanks guys, no one wants to open up a master. Their first wish is to change immediately. And this problem happens when the tank is half full, it is a quarter tank and it runs when I first start. Very interesting
08.05.2020 20:40 # 6
nevce
This problem started with me too. The car does not start for 15 seconds when the car stops for 5 minutes, then it takes it tomorrow.
08.05.2020 20:40 # 7
RP393
[QUOTE = nevce] This problem started in me too, when the car stopped for 5 minutes, it does not start for 15 seconds, then it takes it tomorrow.
Pump pressure may be low and delivering fuel slowly. Turn on the ignition and wait for a while to start and try. Or the fuel is running back and there may be a 15 sec event that you mentioned to fill the line. If there is no leakage from one place, the pump should be disassembled and inspected in both cases.
08.05.2020 20:40 # 8
monalos
If the float changes, take the original, there is a shortage of sub-industries, either it does not show gasoline correctly or the pump's bar is low.
08.05.2020 20:40 # 9
nevce
6, I write the solution here, thank you guys
08.05.2020 20:40 # 10
senalcay
There was a smell of gasoline inside my car. There was a crack in the gas pump body, it changed completely. The brand Messmer was a German patented Italian production. It was changed to 350 TL, the problem was solved. The original was 800 TL.
08.05.2020 20:40 # 11
hakani
[QUOTE = senalcay] There was a smell of gasoline inside my car. There was a crack in the gas pump body, it changed completely. The brand Messmer was a German patented Italian production. It was changed to 350 TL, the problem was resolved. The original was 800 TL.
[/ QUOTE] 307? What did they charge for the exchange fee? I wonder from which province ??
08.05.2020 20:40 # 12
senalcay
No 206. But it does not change much in 307. It changed to 350 TL. I am in Eskişehir.
senalcay 2017-12-27 14:24:00
08.05.2020 20:40 # 13
nevce
Friends pump has changed but it was said to be low pressure, now they will wear high pressure, I could not go because of work, this week we realized that the pressure value will change, I hope it is from the pump because it stops and it looks like it stops, it is from a place that drains the pipes but let's write again
08.05.2020 20:40 # 14
nevce
Friends, the pump has changed, the float is good, there was also a gasoline valve on the engine, they looked from there for pressure control, but the pressure is good but the result is frustrated. how did i not understand
08.05.2020 20:40 # 15
And my brother, look at the gas roles.
08.05.2020 20:40 # 16
nevce
Friends I found the problem myself When the LPG closes, that is, when the distance from the tank and the distance between them is finished, the car is running smoothly, probably gasoline and LPG do not work together as a result of the researches I have done, I would like to cut off the gas and check it.
