Gasoline automatic 407 is taken?
08.05.2020 20:16 # 1
alicelik20
Hello friends. I sold 206 vehicles, I decided to buy 407 because I couldn't find clean accident sand gray roland. I decided on a vehicle. The car is a 2005 model petrol lpg 250 thousand km and automatic. The only thing that scares me is the gearbox. Can this 4-speed automatic transmission work for me? What should I look for when buying?
08.05.2020 20:16 # 2
There are chronic problems in those shamans, of course, we cannot know how it was done. If you take it and cause problems after 1-2 weeks, it may cost you a lot.
08.05.2020 20:16 # 3
alicelik20
If there is any problem with the gearbox, how can this be understood? Let's say I have purchased trouble-free gearboxes and started using this gearbox, does it have a lifetime or how long can it work for me? I used the tiptronic gear of a friend. Since I did not intend to buy a car other than Peugeot, I said I would buy the automatic of the 407.
08.05.2020 20:16 # 4
km very often 200-250 thousand of them, their shamanimas are revised, in fact, is a situation related to this use. usually knocked out on the first departures etc. In fact, when the engine and transmission do not heat, this type of knock can occur.
08.05.2020 20:16 # 5
KILIC
Test it in the hot weather will be a bit of an abnormality in some tight gear shifts. Drive the car for at least 1 hour. If possible, make 30-40 km long roads.
08.05.2020 20:16 # 6
talip206
In general, if there are problems, it will happen in two cases.
1. When the engine transmission is cold. To do this, you have to run and drive the car first. However, the contact should not be open for at least two hours in advance so that the engine should be thoroughly cold.
Kickback knock failure lights come on, etc. It is a rare occurrence that it causes trouble when it is cold.
2. The engine and transmission do so when they are hot or overheated. In order for this to be understood, you need to enter a traffic like Istanbul traffic and use it for at least half an hour, stop and get up, if there is a problem.
But for the final result, it is necessary to cut some money and consult a good gearbox master. It is necessary to connect the device and look at the fault records, if any.
A good fully automatic gear does not miss back from a flat ground up to a 10-degree slope. After 10 degrees, he starts to miss gradually. It is normal to miss back as the angle gets bigger.
08.05.2020 20:16 # 7
OguzhanKucuk61
In 2005, we bought a 2004 model 1.4 petrol automatic 206 at 60 thousand km. We used up to 80 thousand, during this time the transmission got stuck occasionally. Their passage is bad and slow and unstable. If you are going to buy it automatically, I prefer another brand. In today's technology, the 4-speed gearbox is a bit outdated. Of course it's a bit of a budget issue, but if you don't have an automatic obligation, it won't hurt your head manually
08.05.2020 20:16 # 8
talip206
[QUOTE = OguzhanKucuk61] In 2005, we bought 2004 model 1.4 petrol automatic 206 at 60 thousand km. We used up to 80 thousand, during this time the transmission got stuck occasionally. Their passage is bad and slow and unstable. If you are going to buy it automatically, I prefer another brand. In today's technology, the 4-speed gearbox is a bit outdated. Of course it's a bit of a budget issue, but if you don't have automatic obligation, it won't hurt your head manually [/ QUOTE]
Unfortunately, the tools of many brands that are fully automatic are 4 gears. From civic to fluence. Those with 6 and 7 gears are semi-automatic. There is a print (grip) end event in semi-automatic gear, and almost peugeot automatic gear costs even more than revision money.
Fully automatic burns 4 gears, screams or something but long life. Of course, the Japanese are very good at this.
08.05.2020 20:16 # 9
alicelik20
It is a problem to buy, a problem to sell. According to my head, I couldn't find the car getting everything second trouble.
08.05.2020 20:16 # 10
Oktkor
If we don't buy one for ourselves, we can actually get zero for the same money.
08.05.2020 20:16 # 11
alicelik20
They prevent the nation from buying vehicles as much as possible by saying that we should not make a new road traffic jam. Some say there should be no money flow out, and the state made a car and we didn't take it. By the way, I think I will get a 407 of comfort at 1.6 diesel manual 263 thousand km.
08.05.2020 20:16 # 12
ggitaristt
Is there a generation event and difference in the 407s?
For example, there are 3 generations in 307.
Footnote: Gasoline engine does not taste the car at that weight.
ggitaristt 2017-03-29 00:15:10
08.05.2020 20:16 # 13
alicelik20
The man wrote that there is no changing paint in the advertisement. Calling on the phone, my brother has written 5 pieces of paint on the front hood of the vehicle. When there are such men, going out of the city and buying a car scares a lot. The pert-free car pert comes out in our country.
