GASOLINE AND IGNITION ROLE
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
07.05.2024 09:40 # 1
ZD106
Peace be upon you, I have a 1.4 Quick 106. Pressurized fuel is reaching the injector, but the car won't start. Could it be that the fuel relay is supplying electricity to the pump but not the ignition? I installed a Brucke relay, but it didn't start the car. A Hellux relay didn't fit the socket anyway. I'm looking forward to hearing from those who have experienced relay problems and how they solved them. Note: The coil, crank sensor, spark plugs, and temperature sensor are the replaced parts.
03.11.2025 17:39 # 2
Sari37
Sir, did you solve the problem? I am having the same problem. By the way, I also have zd106 redYellow372025-11-03 17:41:33
03.11.2025 20:09 # 3
Emirhno6
206 Gti has the same problem, did you solve it?
