Gasoline 306 XR
08.05.2020 15:15 # 1
insomnia
Distinguished friends, Pug is a brave courageous friend who tears up and embraces the legendary.
My car 306 XR 2000 model is a short time ago at 110 000 km
4 original spark plugs
Original air filter
Original oil and oil filter (I have a short time I did not change)
Original gasoline filter
I just changed my car to the machine and made it look at the exhaust values, they said everything was normal, not a master of meatballs, I would like to ask now one of our most popular masters.
What should be the maximum fuel values that my vehicle will burn in a short and long distance seems to be much higher than normal
08.05.2020 15:15 # 2
He heee :) Bro, thank you, I think you found it :)
08.05.2020 15:15 # 3
insomnia
Write me, how many cents do you burn?
08.05.2020 15:15 # 4
Write [QUOTE = insomnia] how many cents do you burn stop
2 times yours:
08.05.2020 15:15 # 5
insomnia
[QUOTE = cafridion] [QUOTE = insomnia] write me how many cents do you burn stop
2 times yours:
Let me ask you how many kilometers you can go with 20 TL gasoline short distance
08.05.2020 15:15 # 6
Write [QUOTE = insomnia] [QUOTE = cafridion] [QUOTE = insomnia] how many cents do you burn stop
2 times yours:
Brother, I'm going to go a little.
the cafridio 2011-04-09 20:51:05
08.05.2020 15:15 # 7
my idea will burn at least 9-10lt in the city ...
08.05.2020 15:15 # 8
insomnia
My friends, I went around 120 km with the latest 50 TL gasoline and when I bought the 50 TL gasoline, I could go 90 km but I was able to smell the exhaust.
Cecoli master, the idea of what I will burn if I go medium decision on this long road
08.05.2020 15:15 # 9
If you have made 120 with 50 tl, it will be 42k km. this makes an average of 10lt :))
When you make 90 with 50 TL, the km will be 55 kr. this makes 13.5 lt: DDDDD
do your comparison ...
If you decide to go medium on the long road, you will burn 7-7.5lt or something. if you use up to 6 lt of dusers ...
the cecol 2011-04-09 23:07:06
08.05.2020 15:15 # 10
insomnia
[QUOTE = cecoli] If you made 120 with 50 rubles, it will be 42 kr per km. this makes an average of 10lt :))
cecoli master when burning a car, it seems that it is not wrong for me to use a calm, it will not be wrong for me, I will make an account book at the end of this month.
08.05.2020 15:15 # 11
BAHTIYAR
[QUOTE = insomnia] [QUOTE = cecoli] If you made 120 with 50 tl, it will be 42kr per km. this makes an average of 10lt :))
[/ QUOTE] 50 pounds lpg in the city, you make 200 -230km more than 50 pounds more than 300 km intercity
08.05.2020 15:15 # 12
insomnia
[/ QUOTE] In the city, you make 200 - 230 km with 50 pounds of lpg. Even more than 50 pounds in cities will go more than 300 km. [/ QUOTE]
Actually, I think seriously, my fear is that I use torque and revolving vehicles at short or long distances, even though I use the revolving vehicle at the moment when I switch to gas, I have to make an average of 2 times the distance with the same money as you say.
08.05.2020 15:15 # 13
BAHTIYAR
[QUOTE = insomnia]
the more bread the meatballs :), the more the gas consumption increases, the same proportion of the tube will increase. If the assembly is good, there is no loss in performance. LPG) changes between short-range measurement can produce very misleading results (do not compare with my vehicle is automatic and 4 of them will burn less than your vehicle)
08.05.2020 15:15 # 14
the saving rate is not 50%. so you can't make 2 times the same money. it is at most 40% like. Because at the moment, if we take into account that lpg 2.3 TL gasoline is 4.15 ... lpg in average, 10% more than lpg is consumed, the most savings do not exceed 40%.
after all, you press the gas, this tool will burn with the carpet. but if you use it, it will be economical. I burn 10-11 liters of LPG with 1.8 machines without excess gassing ...
With your use, I guess you will not exceed 200 km with 50 TL :)) at least 25 kr.
If you go outside the city, you can travel 100 km with 7 LT lpg. If you are not going to sell your vehicle right away, think about it. How many friends got it from here, everyone thought why I waited so long then it will be thought :)
the cecol 2011-04-10 23:21:55
08.05.2020 15:15 # 15
tugrahan
engines are not the same but you can compare again
306 xr 1.8 16 v 50 tl lpg = 250 km (1 km = 20 krş)
urban 11-12 liter lpg (1 km = 26 krş)
1 month ago LPG was not installed
50 TL gasoline = 160 km (1 km = 32 krş)
city net 10 liters (1 km = 42 krş)
I traveled with 2000 km lpg in 1 month
2000 X 15 krş (average) = 300 TL in pocket
three up to five up accounts like this, the engine is quieter at lpg
this means that it requires extra additives such as longer oil requirement, non-polluted oil etc.
Your information!
08.05.2020 15:15 # 16
yes in your tugrahan the fuel is similar to mine :)) our engines are already bro :))
It saves 16kr per km in the city. what more do you want :))
Also, they say it burns 1.8 motors very much and I can laugh and pass. 1.6s do not burn less than our machine ... besides, our engine burns less than 1.6s :)))
the cecol 2011-04-10 23:41:17
08.05.2020 15:15 # 17
106_arts
[QUOTE = cecoli] yes, it is in the same amount of fuel as in my own machine :)) our engines are already bro :))
how is the 206 from the 110hp series?
08.05.2020 15:15 # 18
I can't beat the weight of 1.6 110hp 206, but this is around 1.8 16v 1150kg. If you compare the engines in general, the values are very close to 1.6 110hp, 1.8 16v. Because this is a 1.6 newer machine. but 1.8 16v more attack side :)) generates more torque at higher and lower rpm ...
08.05.2020 15:15 # 19
106_arts
[QUOTE = cecoli] 1.6 110hp I can't beat the weight of 206 but this is around 1.8 16v 1150kg. If you compare the engines in general, the values are very close to 1.6 110hp, 1.8 16v. Because this is a 1.6 newer machine. but 1.8 16v more attack side :)) generates more torque at higher and lower rpm ... [/ QUOTE]
I looked at the net, it says 306 or 1080 weight, and the 2000 model shows different models with 1.8 306 and 1999 models.
I came to the scale personally with 206 1050 came with lpg
08.05.2020 15:15 # 20
[QUOTE = 106_arts] [QUOTE = cecoli] 1.6 I can't beat the weight of 110hp 206, but this is around 1.8 16v 1150kg. If you compare the engines in general, the values are very close to 1.6 110hp, 1.8 16v. Because this is a 1.6 newer machine. but 1.8 16v more attack side :)) generates more torque at higher and lower rpm ... [/ QUOTE]
Yes, you are right. Because 1130kg for me, the sedan has no liquid carpet. Yurur Halı is 1150. Mine is LPG vs 1200.
The engines of the 99 and 2000 models are the same. there are already 2 medical engines. 16v and 8v. models with automatic gearbox have 8v motor. 16v in straight gear.
The 1.8 16v engine was produced in 97. as well as 97 and later straight 1.8's 16v ...
Page : / 2
