Gasket replacement cost
08.05.2020 21:21 # 1
madi06
Hello friends, my vehicle is constantly decreasing water and when I turned the car ignition for a while, it was not working, there was a temperature problem before ... and if I left the master today, the car will cost 800 TL if the starter motor change is possible, and 3000,4000 TL if the gasket is burned. Do you think these prices are realistic? By the way, my car is 2001 206 XR automatic. Are there any places you can recommend in Ankara for a more affordable price? These prices are really high.
08.05.2020 21:21 # 2
First of all, welcome to us. I think the master is quite a flying bro. only the gasket does not hold up to change, you will reset many parts of the car to that money. ivedik mas mas peugeot has abdullah master is a young master who is very experienced in 206, and tell me my salvation about the price it will help my brother won't hold it up so the top cover will be removed and I hope it will go to the control, crack etc. or. you can contact me. mobile phone 0505 789 36 33
08.05.2020 21:21 # 3
madi06
Thank you, Soner.
08.05.2020 21:21 # 4
Pejoant
For 4 thousand TL, you can renew many parts of the engine, leave the engine and enter other parts. What is 4 thousand? Mercedes is the last model. look elsewhere.
08.05.2020 21:21 # 5
Pejocu Adam
He asked for a lot of money, go away softly
08.05.2020 21:21 # 6
madi06
How many liras would be a reasonable price?
08.05.2020 21:21 # 7
[QUOTE = madi06] How many lira would be a reasonable price? [/ QUOTE]
My teacher can come up with a list that you say first. many of them will depend on your will.
1- the top cover will go to the turner, 250-300 TL
2- cylinder head gasket (150 TL)
3-antifreeze (50 TL)
4-oil and oil filter (150 TL)
5- timing (depending on the situation, if it has not changed at all, it is useful to change) 250-300 TL
6-cycle pump (150 TL)
7- V-belt (no need to improve the situation, but it is useful to replace if there is wear) (if you buy 50 TL belt set about 150 TL)
8-spark plugs (if not changed for a long time) (50 TL)
9- It depends on the craftsman. (500 TL is the worst)
Of course, as an extra recommendation, if the rocker cover gasket, spare water tank cover and thermostat replacement are made, it will be clean. if you will take it for a long time. Also, if the radiator hoses are old, replace them too. It had happened to me. Even if it looked solid, it had been stripped from the clamp and had the gasket burned again. I can help you with the part, brother, we will give you a little more discount. There is a familiar particle in the shameless. I think 2000 TL will solve this job.
01.10.2025 21:18 # 8
konfor
Hey, hey, look how the prices have changed. Peugeot 106, 206. 3061.4, 1.6 Gasoline 23,750 TL Source
