Gasket Change Price ???
08.05.2020 20:16 # 1
Dralp
It was said as if the gasket was burned for my vehicle. There is no falling from the draft. The gasket is burning from the ground as much as the pin is fired, the room is beating with pressure, it was said. The price can be increased between 500 and 800 TL. Another repairman said the price pole price was 800 TL. Are these prices normal ??? What is it that makes this work so expensive ???
Dralp 2017-03-27 17:16:07
08.05.2020 20:16 # 2
Let's say get well soon, let's say roughly
1- They want a price between 200-400 TL for workmanship.
2 - 150-200 TL between top cover grinding turning
3-seals etc. Between 100-150 TL
4-antifreeze etc. trinkets - trinkets between 50-100 rubles
5-circulation pump between 100-150 tl
6-I suggest you change the timing set if it has not changed
7-If not, I recommend you to change the v-belt and bearing.
08.05.2020 20:16 # 3
lz307
2004 I HAVE 307 GASOLINE WITH ME EVEN 1 WEEK BEFORE I HAVE AN EVENT
Not as exaggerated
You can find the parts at the affordable price on the Internet
WORKING 300 TL
REKTEFE 80 TL
TOP COVER TOOL GASKET 120
TRIGER SET 150
TRIGER REPLACE HAS BEEN MORE THAN 7K KM, I HAVE CHANGED AGAIN
WATERPUMP THERMOSTAT OIL FILTERS
ANTIFIREK I PASSED THROUGH A NUMBER OF 1,000 1,100
08.05.2020 20:16 # 4
Dralp
The vehicle was opened today, the master engine would be better if it enters complete competition. He pronounced a figure of 4-5 thousand TL. Does this price normal?
Dralp 2017-03-30 14:23:34
08.05.2020 20:16 # 5
Well, teacher 3 years ago, 1.6 focus 1 3300 TL 9 installments made in the industry, the price is considered normal. I have to research the parts well, I recommend you to use some parts originally, hodja.
08.05.2020 20:16 # 6
without forgetting, the logical teacher operating cost in the zero-crate engine is around 1000 TL and the engine itself is around 5000 TL
08.05.2020 20:16 # 7
hzr206
teacher, what is a 4-5 thousand joke? Is this in İzmir, I make it to the recipe at most 2 billion? all gasket injector cleaning was done, I gave 200 TL in total.
08.05.2020 20:16 # 8
@ hzr06 when you become a familiar master there is no problem, teacher, you can get a suitable price. there were two installments in it Smile when the master is familiar
08.05.2020 20:16 # 9
karaca61
vehicle 307 1.6 hdi 246.000 km first owner turbo maintenance 700 TL material 1650 segments will be thrown in the maintenance of 10000 will not say it but it will not be said, but if we say apricots, it was not talked about, we think the master will find 4000 rubles.
