gases by itself, suffocates
08.05.2020 20:19 # 1
fatih3275
Hi everyone, my car is 106xr, it gives gas to itself. it stops when the car is operating normally, but when I first start it, it is as if the pistons are choking as if it is full of gasoline. ned is
08.05.2020 20:19 # 2
Hello, first of all welcome to us. When it comes to the problem, the idling engine may be defective, this is a cheap part, but unfortunately the engine does not smoke. If there is water reduction, the cylinder head gasket needs to be changed, if there is no water addition, if the vehicle decreases the oil, there is a problem in the circulation and the engine may be damaged.
08.05.2020 20:19 # 3
fatih3275
Thank you, thank you. There is already a loss of oil in the vehicle, but not much, water does not decrease. Idle valve has changed, manifold has changed, room has changed, but the problem continues.
08.05.2020 20:19 # 4
fatih3275
Bidet does not throw out much smoke, it just comes out too much when I first start it.
08.05.2020 20:19 # 5
I realized that my teacher did not run the first, smoke injectors-gas pump-bobbins may be a problem. clean the throttle and have the throttle sensor checked. As you said, have the oxygen sensor checked.
08.05.2020 20:19 # 6
fatih3275
very thank you throttle, the previous owner has replaced the gas pump, with the pump n
how about it may be a nuisance
08.05.2020 20:19 # 7
sending too much or missing petrol can cause the vehicle to work irregularly.
08.05.2020 20:19 # 8
fatih3275
I understand, teacher, thank you.
