gas self-stop and stop at idle
08.05.2020 19:17 # 1
ekremykk
First of all my friends, my friend 106 Quiksilver gives gas to himself when idling, sometimes even cozy and even comes up to 4000 revolutions, sometimes it drops and stops under 1000 thousand cycles. Exclamation
08.05.2020 19:17 # 2
themurat54
If the car is LPG, take it to a LPG PC, connect it to the PC and make a calibration.
08.05.2020 19:17 # 3
GokhaN
[QUOTE = themurat54] If the car is LPG, take it to a LPG, connect it to the PC and do the calibration.
+ things to look at, idling sensor, oxygen sensor, butterfly throat
08.05.2020 19:17 # 4
Cyrus35
Sec. In addition to the manager and as someone who has the same problem, I want to add the crank speed sensor. It is a piece that is not too expensive and does not have to be an effort to change. Awaiting your comment on your situation can help you with friends who have the same problem.
08.05.2020 19:17 # 5
ekremykk
I would like to thank you very much for the information you provided and my first job will be to have them checked.
08.05.2020 19:17 # 6
eren106
Clean the idle sensor, I had the same problem.
