Gas pump sound while in park ?????
08.05.2020 18:06 # 1
kursat3006
Friends, I want to share a situation that I noticed long ago, I couldn't make sense of and found no solution.
Now it is; After parking the car and closing the doors, there is a sound like "vujjiiikkh" from the pump, so I am almost sure that it came from the pump. car petrol pumps are exactly the same sound .. And when I went to the balcony at night, I came across the balcony a few times, and while I was sitting in the car, I was at certain intervals. (With this sound, the light of the tube blinks once and goes out instantly, maybe this happens in half a second)
And I travel 800 km in 3 weeks and spend 50 TL on gasoline. Do you think this is normal or does this sound affect this?
Thanks to everyone in advance :)
08.05.2020 18:06 # 2
mev347
Could it be direct electricity to the pump
08.05.2020 18:06 # 3
kursat3006
I had it checked too, there is no electricity when the ignition is off .. there is no sound in the car.
08.05.2020 18:06 # 4
mev347
Well, if there is no electricity in the pump, I wonder where it can come from. Does it always come or does it come from time to time? Also 800 km or 50 TL gasoline?
08.05.2020 18:06 # 5
kursat3006
So sit half an hour and hear it once. I'm going with 800 km of gas, and at the same time, 50 TL gasoline yakiyo (ordered)
08.05.2020 18:06 # 6
mev347
If it comes from time to time, then it may be in the problem caused by the brain.
08.05.2020 18:06 # 7
kuscu38
My teacher, I suffer from that trouble, I did not have that sound. I realized that gasoline decreased when I came from Ankara. Anyway, I came, I turned the car off, it sounds from what you said, I go out to the balcony, when you listen, you can easily understand that the sound is coming. that sound comes from the gas pump, if the car is low on gasoline, jams in the gas hoses, dirt, etc. If there are such things, it is difficult to go to the engine, trying to pump to the news, the room makes noise. But I could not make any sense that the light of the tube came on. There is no sound from my son right now. Try to put the gasoline too much, the sound will be lost ...
08.05.2020 18:06 # 8
kursat3006
I will try, thank you, I just noticed the tube lights.
08.05.2020 18:06 # 9
kuscu38
I looked at it tonight, because it was gasoline, it did not sound much, it does not usually sound when it is already missing.
08.05.2020 18:06 # 10
kursat3006
Mine does it, but still gasoline is low :)
08.05.2020 18:06 # 11
kuscu38
[QUOTE = kursat3006] Mine is doing but still low on gas:) [/ QUOTE]
go to a solid electrician you know, lift the right rear seat, you will see the gas pump under it, turn off the ignition, check if there is electricity coming with those meter instruments or check the fuses of the gas pump if it is coming! I want you to try maybe it will work!
08.05.2020 18:06 # 12
kursat3006
I tried it, there is no electricity, gasoline is off, the worst is that we cannot prove our problems or show any solution :)
08.05.2020 18:06 # 13
kuscu38
I have not been going to industry for a long time, it will be almost a week, it will be a long time for me :) I will look at the shop tomorrow, let's ask the master, too :) I will remember me tomorrow at a message.
08.05.2020 18:06 # 14
kursat3006
Did you ask the master, Naptin? :)
08.05.2020 18:06 # 15
kuscu38
Don't look at me yesterday, I didn't think it came to my mind, when I got out of the watch, I was stunned ... anyway, I asked, I just came out and went to the electrician, took out the gas pump and waited, because the gas was low, I thought it was not the gas pump in the back of the LPG tank. There is no sense of electricity from the auto to the stop we stopped! Look at him when I return from work tomorrow I will go to LPG and change it anyway. LOL
08.05.2020 18:06 # 16
kursat3006
Come on, I have pump pump for 1 year, thank you :) Thank you it was really good I didn't know that I changed the brain last year
08.05.2020 18:06 # 17
kuscu38
Have a look, if not from her, we will be back to the gas pump again :)
08.05.2020 18:06 # 18
kursat3006
Let's continue writing the developments here :)
08.05.2020 18:06 # 19
kursat3006
Recep, I chose the money, went, bought gasoline, indicator 3/8 (just under my half) but still the sound continues. What about you?
08.05.2020 18:06 # 20
kuscu38
[QUOTE = kursat3006] Recep, I cut the money, went, bought gasoline indicator 3/8 (halfway halfway) but still the sound continues. What about you? [/ QUOTE]
Well, my teacher, I have a bigger problem than him right now.
Page : / 2
