Gas problem at 307 start-up
08.05.2020 17:00 # 1
mesutay20
I opened this issue once more but there was no solution .. 307 xt 1.6 16v 2003 model. the first start of the morning starts, but it doesn't work because it doesn't see the gasoline. sometimes it runs on the 2nd or even the 3rd time. trying to say and do different things, no matter which master I showed. spark plugs changed, filters changed, throttle and seat cleaned and adjusted. did not happen. The last thing to say is either from the gas pump or the tank float. According to what is said, when it is first operated on you, it does not work because there is no gasoline. In these two cases, the costs are 250 TL each. which should I do now? If there is anybody who knows the master in this matter, whatever prayers he will call me. because winter is coming, it may be more problematic.
08.05.2020 17:00 # 2
Do you have LPG in your vehicle?
08.05.2020 17:00 # 3
mesutay20
yes, but they don't think it has anything to do with lpg. when I use it a lot during the day, it does not matter when it switches to lpg immediately ..
08.05.2020 17:00 # 4
salihata
[QUOTE = mesutay20] yes, but they don't think it has anything to do with lpg. When I use it a lot during the day, it does not have a problem when it switches to LPG. I wanted your information.
08.05.2020 17:00 # 5
mesutay20
thank you .. but i need a permanent solution
08.05.2020 17:00 # 6
If the problem is in the gas pump, if you use & nbsp; lpg at the first start, there shouldn't be any problem. Try this.
& nbsp; a petrol pump contact & nbsp; When the key is turned from level 1 to level 2, it makes a noise - does it sound from the vehicle?
08.05.2020 17:00 # 7
ttaylanaa
& nbsp; Probably a gas pump because the gas pump is damaged in lpg cars over time ...
What friends say Run your car directly in LPG, let's see if you will encounter the same problem?
If your vehicle starts immediately, your 90% gas pump does not work well.
Reviews
Reviews
08.05.2020 17:00 # 8
mesutay20
no problem when it passes lpegey quickly. it works normally. I never heard the buzz you said ..
08.05.2020 17:00 # 9
volkan_uysal
So when there is gas in the vehicle, is there a problem when the indicator shows correctly?
08.05.2020 17:00 # 10
mesutay20
no indicator is also not healthy ....
08.05.2020 17:00 # 11
AydinBeyol
this problem was also in my vehicle. I researched for a long time. I finally found a solution that worked for me. The problem of running a few starters in the mornings and gas cuts was due to the vehicle's partial loss of gasoline, which was left unused for a long time in the gas tank. When gasoline is cut in half or a quarter in the tank, usually everyone fuller & nbsp; gasoline. but in this case, the old gasoline is still in the tank, which prevents the engine from running properly when gasoline is low. My suggestion is to finish until the gasoline is completely exhausted or even a gram left, and then buy as much gasoline as we will use. Gasoline friends who lost their quality in 3 or 4 weeks. for your information. I tried it, there is no problem with my vehicle running in the morning. you can try too. you won't lose anything. if there is a problem with other mechanical parts (gas pump, throttle, spark plugs or any part) I cannot know it. as far as i know. & nbsp;
08.05.2020 17:00 # 12
ozaannn
[QUOTE = mesutay20] I opened this issue once more but there was no solution .. 307 xt 1.6 16v 2003 model. the first start of the morning starts, but it doesn't work because it doesn't see the gasoline. sometimes it runs on the 2nd or even the 3rd time. trying to say and do different things, no matter which master I showed. spark plugs changed, filters changed, throttle and seat cleaned and adjusted. did not happen. The last thing to say is either from the gas pump or the tank float. According to what is said, when it is first operated on you, it does not work because there is no gasoline. In these two cases, the costs are 250 TL each. which should I do now? If there is anybody who knows the master in this matter, whatever prayers he will call me. Because winter is coming, it may be more problematic. ; Change, but if it doesn't happen, I can not guarantee when I say I give money. I collect the money from the street. 3 bars are pressed, but there is no drop in pressure. We sent gasoline to the vehicle with a pressure of 1.5 bar from another place. The vehicle started without any problems.
08.05.2020 17:00 # 13
mesutay20
"Smile" & nbsp; friends, I am not a master today to go to the industry and travel to find a definitive solution to this problem. but I wanted to get it cheap. because gasoline pump prices are between 200-400. My research finally found that the problem was caused by the pump motor inside the gas pump. I immediately went and bought one. already included with the filter. I bought the price from 50 & nbsp; tl to 40 tl. I took it to the private service and asked for 40 TL. I went home and opened the back seat. He hit the head of a screwdriver with a hammer and turned the cover. but I had a hard time. anyway i removed the pump. There was a gas outlet and an electric shock. I removed them. I removed the pump motor and changed it. I thought the gasoline was empty, but I hope the tank was almost full. I didn't understand anything from the buoy, but believe me the pump is almost mud inside. always smelled of poor quality gasoline and thinner. anyway I install and replace the pump. When we say bismillah and put the ignition to 2, the sound of the engine started to sound. now like clockwork. Thank goodness I started to work 40 TL for this frustrating situation they wanted 500 TL for manual labor. Pay attention only when connecting electrical wires to the pump motor. be solid .. come on good. I took the photos. I'll load it soon ...
08.05.2020 17:00 # 14
ozaannn
The same problem exists in me, my friend, I have a few more points I would like to ask you.
