Gas pressure is shimmering water sound
08.05.2020 17:11 # 1
SK108
Hello,
& nbsp;
I have a Peugeot 106 XS vehicle.
& nbsp;
For the last 3-5 days, especially when I run in the morning, there is a sparkling water noise when the car is cold. When it gets warmer, this sound stops. I think it does a little water reduction due to this situation.
& nbsp;
What is the reason for this? Somewhat annoying. ::: ((
& nbsp;
Thank you.
08.05.2020 17:11 # 2
herry
doesn't it come from the wheel part? I think there is water accumulating somewhere there, and when it moves it empties
08.05.2020 17:11 # 3
xMEGANx
& nbsp; may be from straps. When I run it in the morning, it comes from me too. The sound of the belts is warming in 1-2 minutes and the sound is cut off. look at him if you want.
08.05.2020 17:11 # 4
SK108
is not like the wheel part .. it is heard very clearly from the inside of the vehicle and usually a sound that is generated in the middle bong parts of the vehicle passes when the vehicle gets hot ..
& nbsp;
tsk I would.
08.05.2020 17:11 # 5
SK108
As if it could not be said on the belt .. this sound is obvious water sound when the car is cold, it gives a shimmering water sound as it gives a little gas ...
08.05.2020 17:11 # 6
Aziz
I know that sound, there was Diesel albea, he was doing it at work, he said 140 thousand after the service, I asked him, I asked him, I wouldn't know it like this, he said, we would have followed it, he couldn't say anything because he is not now, he did the maintenance of the air conditioner, he changed the oil of the oil , they also added 2l of antifreeze, they were in the invoice copy, maybe for your help, maybe
08.05.2020 17:11 # 7
Serkan
Sir, there is probably air in the radiator, the sound comes from the heating pipes, try to bleed the radiator.
08.05.2020 17:11 # 8
SK108
Yes, it may be a weather event according to my researches. How do we get the weather? If I can solve it without taking it to the master, I will solve it.
Thank you.
08.05.2020 17:11 # 9
Serkan
Sir, I don't know the 106 engine, but probably there are screw-in air caps on the hoses that go to the heating system, the air begins to come out when these caps are loosened and the air is closed when the water comes out.
08.05.2020 17:11 # 10
SK108
okay bro, thank you. I'll try it tomorrow.
& nbsp;
good evening.
08.05.2020 17:11 # 11
herry
have you tried
08.05.2020 17:11 # 12
SK108
yes I have not tried, but the problem has not improved ..
08.05.2020 17:11 # 13
Is there a decrease in cooling water?
08.05.2020 17:11 # 14
cinar87
Are the mats getting wet? If it is getting wet, there may be a leak in the radiator under the torpedo.
08.05.2020 17:11 # 15
xMEGANx
Antifreeze the engine engine water, your problem will be solved. The engine water freezes a little in the water tank or radiator, and the non-freezing water falls from the ice, and the downward sound stems from here. ice melts as water warms. that's why.
