Gas pedal stuck problem while driving.
08.05.2020 16:52 # 1
xpyhre
Greetings. While my 206 gti car is driving on the road, the accelerator pedal gets stuck at the bottom of the ground. This is not continuous. What is the reason?
xpyhre 2012-06-22 01:03:02
08.05.2020 16:52 # 2
EmSul
Whether it was in the mondeo, we had used it for a while. My nephew was using the clutch and wasted, and we stopped and looked at it. I did not use a mat at the moment. I used a clutch on the driver's side 1-2 times, I took it into the trunk. I said I'll tell you a possibility ..
08.05.2020 16:52 # 3
xpyhre
No, no floor mats. When I first got in the car, I had friends with me, they did not believe us when I said I did it unintentionally.
08.05.2020 16:52 # 4
EmSul
If nothing happens, throw it into the clutch, an important situation must be resolved in wasted brakes.
08.05.2020 16:52 # 5
ufuk91
a dangerous situation, take it without waiting for my teacher, show it, god forbid suddenly, if there is a vehicle in front of it, if we do it, we will be in trouble per accident.
08.05.2020 16:52 # 6
ufuk91
[QUOTE = EmSul] Do not get stuck in the mop :) We have been to Mondeo for a while before, my nephew was using the clutch and wasted, and we looked at it. I said that it wouldn't be possible. I didn't say anything. [/ QUOTE]
I did not pull it out of the mat, I couldn't solve it during the day, the last thing comes to mind. border = "0" alt = "LOL" title = "LOL" />
08.05.2020 16:52 # 7
metin
It felt like a mop to me. If there is no mat, there is a pedal jam somewhere. It is also necessary to check the broadcast
08.05.2020 16:52 # 8
MagicPerformance
Change the gas wire immediately. For the same reason, I came back from death, the gas wire of the vehicle got stuck, I was dead until it stopped.
08.05.2020 16:52 # 9
ufuk91
[QUOTE = umutrizaergen] immediately change the throttle wire For the same reason, I came back from death, the gas wire of the vehicle got stuck until I stopped it, I stopped, I stopped like it was going at 220+ speed :) :)
change the gas wire without losing any time
Do you think that the vehicle is stopped at that speed? & Nbsp; let's press the clutch & nbsp; and let the vehicle come to mind. 111; nfused "title =" C o nfused "/>
08.05.2020 16:52 # 10
xpyhre
With the current psychology, one can be surprised at what to do.
08.05.2020 16:52 # 11
MagicPerformance
[QUOTE = ufuk91] [QUOTE = umutrizaergen] immediately change the throttle wire For the same reason, I came back from death, the gas wire of the vehicle got stuck until it stopped.
Do you ever stop the vehicle at that speed? & nbsp; let's press the clutch & nbsp; and let the vehicle come to mind, yell at your mind & nbsp; "C [/ QUOTE]
you think you have not tried :) clutch brake does not benefit anything my vehicle 190 hp stopper throttle whatever gone that evening, we went into the circuit breaker in 5th gear :)
08.05.2020 16:52 # 12
ufuk91
You may have kept your coolness from God, whether it is too hard or difficult, no one has come to anyone ...
08.05.2020 16:52 # 13
BULUT06
320DE INSTALLED THE PRESIDENT DRILLED THE CAR 4,500LIRA MOTOR COST EVERYTHING THIS WATER ASK, MAKE IT IMMEDIATELY GIVE US
08.05.2020 16:52 # 14
Brother may have a wood close to the engine under the pedal, squeezing
