Gas Leak Under Air Conditioner Chest
08.05.2020 20:47 # 1
kobe06
Hello friends, I have a problem with air conditioning in my car. I went to the electrician, gas was pressed into the vehicle, leak check was done. No leak was found under the hood, the master got into the vehicle and listened. then he called me. There was a gas leak from the ventilation duct in the chest. He said the chest needs to be removed. After that, the leak is either repaired or it is necessary to replace the radiator (inside the chest that has an air conditioner related radiator). I would be glad if friends with experience with this problem guide. how can i solve the problem. I am thinking of showing it somewhere else. Is there a place you can recommend for Ankara? I'm waiting for your help.
08.05.2020 20:47 # 2
Sir, there are radiators who are dealing with this type of work, not the electrician. There are even air conditioner leak repair fluids, they have to give it a try.
08.05.2020 20:47 # 3
kobe06
[QUOTE = sonerkyl] Sir, there are radiators working on this type of work, not the electrician, sir. There are even air conditioner leak repair fluids, they have to give it a try.
Thank you, teacher. and it would be nice if I found a quality place for this job in Ankara.
08.05.2020 20:47 # 4
Here is my brother, who is a master in that matter. most of them are always looking for a whistle. I would recommend it if it is the place I know about air conditioning. I can only help you with the regular master console.
08.05.2020 20:47 # 5
kobe06
I am glad I have a master who goes to mechanical repair works. but you have to find a good place for this job.
08.05.2020 20:47 # 6
unalt
Is your problem resolved? I'm having the same problem
