Gas Indicator and Isofix
08.05.2020 18:46 # 1
CeRRaH
Hello friends...
I want to get information about two topics
2005 Model 206 Xt I have a Sanrufflu vehicle ...
When the gas light of the vehicle turned on, I bought 20tl gasoline, but the gas light did not go out ... After I traveled 45 km out of the city, I bought another 20tl gas, but the light did not go out again. Is there a problem in those 206s or there is a problem in my car's gas gauge ... I bought 70tl gasoline, I traveled 100 km out of town for the city but did not even move from the pointer ...
second issue is there is isofix in these model vehicles ?? i don't know if i have my own car
08.05.2020 18:46 # 2
Barut
When purchasing less than 7 or 8 liters, the light does not go out and the hand does not move. When it is less than 40 TL at a time, the tank does not detect gasoline.
08.05.2020 18:46 # 3
yalcinoto123
http://www.peugeototocikma.com/ VEHICLE WAREHOUSE VENTILATION DOES NOT OPEN 20 TL GASOLINE VALVE MUST GET AT LEAST 50 TL AFTER DOWNLOADING THE GASOLINE.
08.05.2020 18:46 # 4
Mdeniz
Think of it like this, you will die and eat only one olive, do you get enough, you need to eat cheese, bread and tea, so I will not move any more.
08.05.2020 18:46 # 5
CeRRaH
:) The example is correct. I did not play in the needle even though I bought a total of 70 TL of fuel and only went 100 km.
08.05.2020 18:46 # 6
TaZ
If you take 70 liters of fuel out of sight, why do you take it in such a way that you can sit for 10 minutes and eat it 3 times.
08.05.2020 18:46 # 7
CeRRaH
Actually, he did not ignore it .. but why does not it go out, I wonder if I should break it out, I will get 20 more, 30 more, let's take another 30 :) The car won and the gas light did not go out :)
but from now on I will speak to that gasoline in the language he understands :))
Surgeon 2014-08-27 11:42:54
08.05.2020 18:46 # 8
ahmed206
For some reason, the vehicle pulls the tank as it blows from time to time, rather than at every start.
I have more than half a tank of petrol, close to the last line that appears on the display.
08.05.2020 18:46 # 9
SEZGIN72
The yellow light comes on when 6-7 Lt remains in the tank. When you bought 20 TL, you only bought 5 liters of gasoline, so there was 1-2 liters of gas in the tank so that the yellow light did not go out. If you want to turn off the yellow light. and if you have gone 30-40 km after the yellow light turned on, you should buy at least 7-8 liters of gasoline ...
Don't worry, your vehicle has no problem ...
Good luck with.
08.05.2020 18:46 # 10
koray
This happened in my vehicle. I changed the pump. The master could not sit the pump fully, I was putting gasoline constantly, the hand was not moving. now when I put 30 tl it goes out. If it doesn't fit the pump correctly, it gives the smell of gasoline inside.
