Gas Indicator
08.05.2020 20:45 # 1
kayaca
I have 206 Feline Model Vehicle, I filled the gas 5 days ago or so, I went 70 km or more, the gas is falling down to 2 heat, I looked at the rear samant, 3 lights should be comfortable, the tank is burning in 25 liters of the vehicle. It falls to 2, sometimes it is 50 or so dsüuyo 2, but let's come back, there is gas in the back samarada how can we fix this? Will it improve if we change the indicator on the front panel
08.05.2020 20:45 # 2
Karacocuk24
Unfortunately, if you change 90% of these indicators are not correct, there are studies on the same issue, but again, it is not healthy but the best is enough to know how far you can go with the gas you buy.
08.05.2020 20:45 # 3
kayaca
[QUOTE = Karacocuk24] Unfortunately, 90% of these indicators do not show correct, but if you change, there is still the same work on this subject, but again it is not healthy but it is best to know how long you can go with the gas you bought [/ QUOTE]
I used to know that he used to burn 200 km 62 tl or something.
08.05.2020 20:45 # 4
RP393
Hello, I use a 25 lt cylinder tank. Zavoli kit is attached.
I fill it in full. In the city, 3 teeth remain after 100 km. It remains 2 at 140 km. 1 tooth remains around 180 km. It turns red at 200. 240 fln ends. This way for 1 year continuously. The float in the tank may not be sensitive to you. With 1 warehouse, you can detect the total km and make it follow. RP393 2018-02-09 18:58:44
