Gas gauge solution
08.05.2020 20:55 # 1
cerkesceyhun
As you know, after installing the LPG, the gas gauge is troubled.
08.05.2020 20:55 # 2
First of all, welcome to us. every time you start the psa module hojam vehicle, the product you call brings the gasoline needle to where it should be by resetting. I use LPG, it falls bended, I do not need it. Obviously, there is no need to pay 150-200 TL. I usually have about half a tank of petrol, as the needle makes a dip, it reset itself and brings it to where it should be. I say buy a gas for that money.
08.05.2020 20:55 # 3
cerkesceyhun
Thank you. Thank you ... I understand that it will be the place where it was located after resetting, not the place it was reset, right?
08.05.2020 20:55 # 4
Exactly, teacher.
08.05.2020 20:55 # 5
bilo131
It's not exactly about the subject, but I got the wastes mind series about 3 months ago. In the first time, my gasoline needle was not pointing correctly. Then he recovered spontaneously. There is no problem right now. I don't know why, but miserable it works.
08.05.2020 20:55 # 6
cerkesceyhun
thank you so much
