gas gauge
08.05.2020 16:20 # 1
sagalassos
Hello friends. Finally, I was able to find a 307 xt according to my head. I bought the car 3 days before the holiday. I did 1500 km during the holiday, there is no problem in the car, the engine, the bonnet, but the gas gauge drops incredibly when I use it in lpg, BRC There is a brand lpg kit, as a result of my research, either there is a system called PSA module, they do not guarantee this system, a second solution was to connect a 47 ohm resistor to the float cables coming out of the gas pump and to complete the system with a spring switch. If you have friends who have advice, I ask for your help .. Thanks.
08.05.2020 16:20 # 2
VEDATDINC
The system is very cheap and runs smoothly. You are holding the key down. You bring the contact to the 2nd level. The tank is showing full. You turn off the ignition and wait for 1 minute.
08.05.2020 16:20 # 3
First of all, your vehicle is good. This trouble exists in all French automobiles, but I think it shouldn't be a problem, personally I don't. I add gas to the tank for 5 TL each lpg I buy instead of coming back :)
08.05.2020 16:20 # 4
VEDATDINC
See this link explains how it's done here http://forum.peugeotturkey.com/forum_posts.asp?TID=13780&KW=47+ohm&PID=198150&title= lPG-de-petrol-hand-du-cheap-to-issue # 198 150 RESOLUTION
08.05.2020 16:20 # 5
sagalassos
Thank you both guys. Vedat Bey first confirms what I have given you the link, I think the resistance is a useful solution, but it was not a major problem as my brother said, I filled the gas tank on the day of Eve, Then the pointer was always unreasonable & nbsp; when I was moving, I was very confused, today I bought 10 pounds of gasoline and the pointer came to where it should be. I'm thinking of having a shock absorber, I think this won't be a problem. Thanks again ...
08.05.2020 16:20 # 6
metin
[QUOTE = htasay] First of all, your vehicle is good. This trouble exists in all French automobiles, but I think it shouldn't be a problem, personally I don't. I put gas in the tank at 5 TL each lpg I bought instead of coming back :) If you solve it, let me know, hojam:) the float does not send a signal to the brain, but the pointer does not recover ((
08.05.2020 16:20 # 7
metin
[QUOTE = sagalassos]
Thank you both guys. Vedat Bey first confirms what I have given you the link, I think the resistance is a solution that works, but it was not a very important problem as he said in his brother. I was very confused when I was constantly making unreasonable & nbsp; move, I bought 10 pounds of gasoline today and came to where it was supposed to. I think I'm going to get it, I think this won't be a problem. Thanks again ...
& nbsp; If the fuel in the
tank is more than half the tank, it gets old every time the vehicle is started.
& nbsp;
If there is sound coming from the rear shock absorbers, you can handle it with silicone. Of course, it would be better if you buy a sports shock absorber.
08.05.2020 16:20 # 8
gasoline 4.30 I suppose I bought a maximum of 5.5 or 6 liters of gasoline up to now, my vehicle gets 76 TL lpg I will take 100 I will fill the remaining 24 LPG from the card:) & nbsp;
08.05.2020 16:20 # 9
In other words, it does not wait for me with 7 lt. If you put 5 TL to jump, it gives value to the incoming gas :)
08.05.2020 16:20 # 10
maestro
warehouse & nbsp; if we put a stick and mix it like a drink, would it be okay if I think if it will return to its original state by thinking that it is gasoline "Grin"
08.05.2020 16:20 # 11
volkan_uysal
I do not look at it because my car is only used almost because it is close to the fulle. Whether the indicator shows zero, I think there is no problem & nbsp;
08.05.2020 16:20 # 12
sagalassos
I understood that it was not a problem, but the idea of putting a bar into the tank was good :) I think Volkan Bey, I do not have trouble if you do as you do, I think there will be no question mark when gasoline is always close to full.
08.05.2020 16:20 # 13
volkan_uysal
At first I was taking it once a month, and then I looked it was too much. I finish 4 depots of LPG per month, but 20 tl of fuel is wasting maybe. If I buy 50 TL every 2 months, it is enough. Of course I do not know the monthly km you do. & Nbsp;
I got so used to looking for the gas gauge light when I got on my friend's 307, my eyes & nbsp;
[QUOTE = sagalassos] I realized that it was not a problem, but inserting a stick into the tank The idea was nice :) Volkan Bey, I guess I do not have trouble if you do as you do, I think there will be no question mark when gasoline is always close to full value. So how long do you buy gasoline on average.
08.05.2020 16:20 # 14
ByHack
First of all, my brother should be auspicious and Allah should not cause trouble. As for the questions: 1- The fact that the fuel gauge also decreases in the use of LPG is a situation in most vehicles (on vehicles with trip computers, calculating fuel consumption). the trouble here is this; Other vehicles with a falling indicator on LPG update the ignition, that is, every time you start the vehicle, it updates the fuel information in the tank, but this is not the case in our 307s :) To update the fuel information, you need to get more than 7.5 liters of fuel, which has to be in one go separately. will not be in the amount (if you get 5lt after 3 lt it will not update :). Your indicator will return to normal level when you turn off the ignition of your vehicle, especially if the trip computer measures that you have consumed more than 7.5 liters of fuel when you are on a long road (eg you have traveled 250 km). Installing a PSA module in your vehicle will not prevent the indicator from falling down, it will only benefit to increase the life of the fuel pump and partially decrease the evaporation of the gasoline in the tank. Considering that there is no fuel filter in the 307s, it is also a fact that it does not make sense to operate the pump of the vehicle you are using with LPG. So it is definitely useful to install timing relay (psa). You can have 50 to 100 TL (brand difference may be included) including workmanship in a good electrician or somewhere that converts to LPG. I would not recommend you to interfere with the working principle of the indicator, etc. systems. Peugeot vehicles are sensitive in terms of electronic components compared to their equivalents. so to speak, even if you tighten a screw, the malfunction lamp may come on, the trip computer may show a malfunction :) It has burned the brain of the vehicle in many people trying to apply these and similar systems, causing high financial damage. Considering all these, have PSA module installed, instead of dealing with resistance, when you buy LPG, take 7-8 liters of gasoline, you will spend more than half of the gasoline you have bought until the LPG runs out (known system principle). Apart from these, if there is an issue in your mind, we, as forum residents, cannot withhold our humble knowledge in accordance with our experience. good luck again ...
08.05.2020 16:20 # 15
sagalassos
First of all, thank you very much for the information you have given. When I got to Fiat Uno for many years (which has drawn me very much), it was very enjoyable for me to drive the city of Peugeot. Thanks to you, the tool I bought without paying attention to anyone. Thanks to you, I am confident that the indicator is not a problem anymore. I wish you a pleasant ride without any problems.
08.05.2020 16:20 # 16
[QUOTE = sagalassos] First of all, thank you very much for the information you provided. When I got to Fiat Uno for many years (which attracted me very much), it was very enjoyable for me to say that Peugeot's city ride was very enjoyable. It is due to the fact that it is my first car with as many features but I am fortunate that I bought it without any consideration. Thanks to you, I am sure that the indicator is not a problem anymore. Thank you, I wish everyone enjoyable driving without accident, without any problems. / div>
but I used to have very different vehicles, but in general, this car has a place in another body, I have 307 and more than every other vehicle. I have a fun ride. I have had uno, palio, escort, mercedes, bora, toyota, born, letterpress and many more cars because we have been a galler for a certain period of time. a handsome car is the best part of this price with so many features. I personally do not think that I will give up this car. Because I really love this car "Star"
08.05.2020 16:20 # 17
sagalassos
It was a pleasure to hear these words about 307 from someone who was a galler, who also used 307. `` Don't bother '', `` It costs a lot '', `` There is no market '' etc, etc ... We are so biased that even those who did not use were making negative comments. I rented 2 days 307 for the driving experiment and then I said, `` That's it '' and I bought the vehicle without any hesitation :)
08.05.2020 16:20 # 18
Well, I was angry around here, we had a girl, what was the part of my vehicle was expensive, the oil was expensive, the tire was expensive. Use the same tire, and then burn 2 times of the fuel I burned and then I said to me a luxury enthusiast broke down.
I did not have a car until this car, there were many German cars, German cars had such a feature, they said to them. system, torpedo cooler, four glass automatic, 110bg diesel engine You go, I said, "Get on the German cars without the old black drection air conditioner with the car body rotted at 400.000 km, which burned 2 times of my car, they broke down and I got on top of every discussion. Thank God my car did not give me anything.
08.05.2020 16:20 # 19
Don't worry, brother. You get used to it after a while. & Nbsp; & Nbsp;
08.05.2020 16:20 # 20
VEDATDINC
I bought my car in 2006, so they said to me buying a peugeot at that time there were 307 very few, now there are many & nbsp; and there is a lot of & nbsp; and there is no service here 3 or open in 5 months
