gas cutting problem help
08.05.2020 21:26 # 1
everest
1.6 diesel 308 is working half an hour on my vehicle normal, the problem is okay, but then the water gives the error FAULTY ANTİPOLLİTİON starts cutting gas, I wonder what the engine oil has decreased and help you.
08.05.2020 21:26 # 2
Kenan 976
means catalyst contamination, you need to use it for a short time at low gears and burn it and burn it.
08.05.2020 21:26 # 3
Just like our friend said, the catalyst is filled with professors, poor quality fuel and continuous use at low speed.
08.05.2020 21:26 # 4
everest
the automatic vehicle shifts its gear at the speed it has determined, there is nothing to do to it
08.05.2020 21:26 # 5
[QUOTE = everest] automatic car shifts at the speed set by itself, there is nothing to do to it [/ QUOTE]
Do not have f1 gears, you can use your vehicle to drop gears from your vehicle.
08.05.2020 21:26 # 6
ismailkaya
Look at the car's turbocharger.
08.05.2020 21:26 # 7
everest
Thank you for your help
