Gas cutting problem
08.05.2020 16:42 # 1
biqisi00
my problem is peugeot 307 hdi 110 / 1,6 / 2004 & nbsp; user car 188 thousand all maintenance & nbsp; was done water pump timing belt etc .... vehicle sometimes suddenly cuts the gas, it does not go up, the vehicle seems to stop floating, the lamp is like it stops Heleki then goes on a long road, suddenly cuts the gas, then, when you take your foot from the gas, it gets a few seconds later, and when you do these things, you can sometimes smell black smoke from the back, sometimes you feel a smell of light in the air. / 80 is usually 80 & nbsp; from here & nbsp; a few & nbsp; I had the injector in the 2nd eye missing the first day & nbsp; again, the nbsp; or why is there a n & nbsp;
I went to the peugeot service here & nbsp; the master told me he could be from the particle filter, while cleaning himself, he claimed that he would fix the situation over time. a liquid was available, they put it in gas stations and services, the room was ok during maintenance, but the particle & nbsp; together with the filter & nbsp; maintenance is ok & nbsp; but this can cause a lot of respect regards biqisi00 2012- 04-12 01:08:28
08.05.2020 16:42 # 2
istanbullu_3886
As the service said, it may have been from the particle filter. In my opinion, the Opel brand vehicle had the same problems.
08.05.2020 16:42 # 3
biqisi00
I went to the long road, I did 1000 km & nbsp; the problem still continues.
08.05.2020 16:42 # 4
biqisi00
& nbsp; your comments on this thread & nbsp; tskler
08.05.2020 16:42 # 5
biqisi00
Sir ?
08.05.2020 16:42 # 6
It felt like a particle filter to me. Especially the smell of the institution comes from there.
08.05.2020 16:42 # 7
adanALI...
First of all, my dear friends, I have a 2002 307 xr, and the problem is that while another vehicle is moving on the road in normal driving, it suddenly cuts off the gas but does not stop it works at idle but there is no gas, so the gas pedal is wasted when I stop the car and start it again, there is no problem but it does it again after a while In Kayseri, I called a peugeot service and the person in his phone told me that there was a socket entry on the gas pedal and he cleaned it with oxide remover, and the problem would disappear, and I did it for a while, but now he started again. .
Reviews
08.05.2020 16:42 # 8
adanALI...
And it may have something to do with the oxygen sensor. When it is connected to the computer, the only fault is showing it, but they said it wasn't. & nbsp;
08.05.2020 16:42 # 9
dahi
edit dahi 2013-12-22 14:02:02
08.05.2020 16:42 # 10
rzsrht
[QUOTE = adanALİ ...] first of all, my dm friends got 2002 307 xr and the problem is suddenly cutting off the gas while another vehicle is driving normally on the road, but it does not stop working at idle but there is no gas, so the gas pedal is wasted, when I stop the car and start it again There is no problem but after a while, he is doing it again. I called a peugeot service, and the person in his phone told me that there was a socket entry on the gas pedal and that he would clean it with oxide remover, and I did it. I would be grateful, I would appreciate if you write an answer ...
I had the same problem. the veteran was crossing, but the car continued to run at idle. It's been a month or so, right now, but I don't know if you will do it again. I hope I will benefit if anyone knows the problem ..
08.05.2020 16:42 # 11
blackismortal
I have pego 207 while my friends are on the go, cutting out the gas and getting out of the pedal, I got it 2 weeks before the service, it just got back, I started to do it again.
08.05.2020 16:42 # 12
rzsrht
my brother was doing the same problem in winter as well. I wrote the problem on this site and wrote only once, now there is no bullet in the ear of the devil. but hopefully a friend who knows will read his solution
08.05.2020 16:42 # 13
blackismortal
[QUOTE = adanALİ ...] first of all, my dm friends have 2002 307 xr and the problem is suddenly cutting off the gas while another vehicle is driving normally on the road but it does not stop working at idle but there is no gas, so the gas pedal is wasted when I stop the car and start it again There is no problem but after a while, he is doing it again. I called a peugeot service, and the person in his phone told me that there was a socket entry on the gas pedal and that he would clean it with oxide remover, and I did it. I would be grateful, I would be glad if you write an answer thanks ...
08.05.2020 16:42 # 14
blackismortal
So how did this problem improve? Can you tell me what my brother did?
