Gas Cutting Problem
08.05.2020 13:59 # 1
mbolun
GOOD HELLO MY PROBLEM 106 GTI CUT GAS
I HAVE MADE TEN TOOL NEW INTRODUCTION TO THE TRANSMISSION ENGINE INSTALLATION SPARK PLUGS BITES
HOWEVER, I HAVE THE PROBLEM OF GAS BLOWING IN MY CAR, BUT THE VEHICLE IS CUTTING THE GAS ON THE ROAD, WHEN IT IS ALWAYS, IT DOES NOT ALWAYS.
THERE IS NO REACTION TO THE OLD EVEN 3 OR 4 SECONDS AFTER THE GAS IS FINALLY BACK TO THE OLD STATE, BUT THE LIGHT IN THE ON PANEL, I HAVE THE EXPERIENCE IN THE NORMAL LIGHTS, I HAVE THE PROBLEM, I HAVE THE PROBLEM I HAVE TO EXPERIENCE THERE ARE I HAVE A SENSE I EXPERIENE THAT I HAVE THE EXPERIENCE OF 2 LET'S LOVE THE QUANTITY AFTER THE TRANSFER BUT THIS GAS CUTTING HUMMY FEARS ME WHAT YOU CAN PROBLEM ???
STARBURAKS 2008-12-08 01:32:49
08.05.2020 13:59 # 2
Can there be a problem with gas automatic operation?
08.05.2020 13:59 # 3
When you say gas cutting, you press but don't I? Or is it cutting a certain cycle?
08.05.2020 13:59 # 4
My friend has the problem of gas cutting but the throat of the car is dirty because of the quality of gasoline or spark plugs can not ignite well ...
08.05.2020 13:59 # 5
mbolun
There is no problem in working at the beginning
gasoline filter air filter oil filter engine oil spark plugs new
After getting up when the car is cold or rarely going on the road, it does not eat any gas, it gets like a vehicle.
08.05.2020 13:59 # 6
Has the throttle been checked?
08.05.2020 13:59 # 7
mbolun
no not done :(
08.05.2020 13:59 # 8
The problem arises from spark plugs, he says. It doesn't provide good ignition. You say that I just changed the spark plugs, but I think it will look again.
08.05.2020 13:59 # 9
There is a Paris pejo in Maslak, if you want to visit it, you should talk to our friend Serhat in modified room.
08.05.2020 13:59 # 10
I think it would be useful to check throttle chronic problem in 106 vehicles ...
if you can, you can do it yourself;) +++ spark plug cables ... live 2008-12-08 01:29:06
08.05.2020 13:59 # 11
I think you will disrupt the idle adjustment, do not change it, now :)
08.05.2020 13:59 # 12
mbolun
okey I will come across, I hope that he has debts with his friend:
08.05.2020 13:59 # 13
yes Admin is themselves :)
08.05.2020 13:59 # 14
aoc
Eveeeeet .. I was expecting when this problem would come from someone and it came out. The same happened to me, it didn't do when the engine was hot, but when it was cold, it does it at the beginning and after a while it gets better? O2 sensor brother :) You will get BOSCH brand and 140 lira. Unfortunately, it does not come out, it comes to the vehicle specially (chassis number) and it turns to 180 as you .. Gas pump, spark plug, etc. Do not deal with it;)
How many nail plugs are there in your vehicle?
08.05.2020 13:59 # 15
mbolun
ustudne was with 2 nails I changed one nail but the same thing is going on the nail event is not very important in the case they said single nail double nail is not changing they said o2 senseru
08.05.2020 13:59 # 16
Was there catalyst cancellation in the vehicle?
08.05.2020 13:59 # 17
mbolun
I don't know what you said
08.05.2020 13:59 # 18
[QUOTE = mbolun] I don't know what you said [/ QUOTE]
Reduces noise from exhaust, reduces carbon dioxide to a minimum :)
It is mounted on the exhaust pipe coming out of the engine, it is probably under the right seat ...
It is an apparatus that is useful when you look but it does not work in practice :)
08.05.2020 13:59 # 19
aoc
mbolun, disassemble the master o2 sensor, a burnt sensor will come out. I don't think you can get more confused;) Then you send me the thank you message from here.
08.05.2020 13:59 # 20
sinan-s
o2 sensor-can be throttle or petrol automatic
Page : / 2
