Gas cutting problem
08.05.2020 20:01 # 1
Barut
I wish you a good weekend.
When I pushed the vehicle too hard, for example, when I started with a high speed and went up to a speed of 150-200 km and continued for a long time, I suddenly cut off the gas and displayed an antipoult text on the screen. When the ignition was on and off, it returned to normal. Now he has begun to do this all the time, especially on roads with hills. As soon as the contact is on and off, it improves. Vehicle 206 quiksilver 1.6 110 hp. No lpg. I suspect the gas pump air filter, throat butterfly clean. I tried many stations, the problem continues.
08.05.2020 20:01 # 2
monalos
I also have a similar situation. The car was piling after 3000 rpm. The lamp was on.
08.05.2020 20:01 # 3
Barut
[QUOTE = monalos] I also have a similar situation, the car was going to light up after 3000 cycles, the lamp was burning, the coil changed, it is possible that it is from the coil, it appears when you have it connected to the computer [/ QUOTE] He is constantly doing it according to his head. Let me note the coil. Thank you for the answer
08.05.2020 20:01 # 4
monalos
Then the coil is the same problem as I said.
08.05.2020 20:01 # 5
Selox
It could happen to the crankshaft sensor. I suggest you try if you can find a different sensor. An easy solution would be solved.
