Gas cutting exhaust blasting in the tube |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 306 | |
| 08.05.2020 19:21 | # 1 |
I have a 306 1.6 griffe model vehicle before, there was no problem in my vehicle, it was working better in the tube than gasoline, but now performance 0 let me immediately switch to the problem. There is no problem in gasoline, but the gas does not eat when it presses the gas, I thought the setting was bad. no problem but the problem still knows the same please help.
| 08.05.2020 19:21 | # 2 |
sonerkyl |
First of all, if the pat is doing the explosion more when the vehicle is getting up, look at the lpg map sensor, lpg heat sensor. In our focus, he was making a pat on the first departure and cutting the gas after the replacement of these parts.
| 08.05.2020 19:21 | # 3 |
sonerkyl |
Have a look at the oxygen sensor in my teacher and have the throttle cleaned.
| 08.05.2020 19:21 | # 4 |
Thank you, my vehicle does not do much on take-off, when I touch the gas to increase the speed of normal travel, it does whatever I press on the car, the vehicle is too late for 4000 cycles. |
| 08.05.2020 19:21 | # 5 |
sonerkyl |
[QUOTE = rburhanr] Thanks, my car does not do much on take-off. Normally, when I touch the gas to increase the speed, I do it. teacher, I think the problem is probably replace the lpg map sensor with a new one and have a test
| 08.05.2020 19:21 | # 6 |
No spark plugs are broken. Take 4 spark plugs. Change the vehicle.
| 08.05.2020 19:21 | # 7 |
We solved the problem of the vehicle, collected process injectors, filters, spark plug cables changed but still not solved I left the last car for 2 days. The problem was solved when the cable was broken.
