Gas cutting between 3 thousand and 4 thousand
08.05.2020 18:24 # 1
mamion
First of all, I have been following the peugeot fan page for about 3 years, but for the first time, I am writing 2002 model 206 xt 1.6 16v when I have a car while working, it is as if there is something going on as if there was something to cut, gas cutting between 3000 and 4000 cycles and shaking a little after 4000 cycles.
08.05.2020 18:24 # 2
kursat3006
Clean the throttle, have the calibration done, and I think change the place where you gas first.
08.05.2020 18:24 # 3
mamion
What is the estimated expense, a friend of mine said to the brain
08.05.2020 18:24 # 4
kursat3006
First of all, do what I say and go to the setting does not exceed 50 liras. If you are constantly buying gas, replace it. If the problem is the brain, the veterans understand, but a little salary
Costly brain.
08.05.2020 18:24 # 5
mamion
He does it at gasoline, but I traveled at gasoline for 3 days, the same continues
08.05.2020 18:24 # 6
kursat3006
Then show it to someone who understands what we say from afar. Even before you show some people
08.05.2020 18:24 # 7
elsoberano
First, clean the throttle, then connect it to the computer and have it calibrated, so use it for 2-3 days on gas without taking the gas again.
08.05.2020 18:24 # 8
mamion
Thank you I will go today
