Gas cutting at constant speed
08.05.2020 20:15 # 1
Suayp206
Hello, 2006 model diesel 206 is just bought, it is considered to be cutting the gas when the vehicle is going at a constant speed.
08.05.2020 20:15 # 2
In fact, injectors do not break down very easily in gasoline vehicles and cause more malfunctions in diesel. Generally, these types of problems are caused by air flow meters in these diesel vehicles. however, I say change the station where you buy a diesel. You also checked the crank speed sensor. I think it's from fuel.
08.05.2020 20:15 # 3
KILIC
I do not know exactly what the accelerator pedal is. Check the socket on the gas pedal and clean it with lining spray.
08.05.2020 20:15 # 4
Selox
Gas cutting had also happened to me. It was from the crankshaft sensor. It is necessary to have the original installed. Make a malfunction, if any, it is the crankshaft sensor. Of course mine was stopping from time to time. Selox 2017-03-23 16:16:40
08.05.2020 20:15 # 5
Suayp206
Probably a problem with fuel I bought from fuel, no fuel
08.05.2020 20:15 # 6
Selox
I'm glad, don't praise too much, it's not worth it. D
