Gas cutter taaatatatata Sound. Help
08.05.2020 16:35 # 1
bilmem26
How do I see the gas cutter thing I see in the vehicle?
08.05.2020 16:35 # 2
aspirinxlarge
Ha haa I love that sound too, & nbsp; but I'm not printing that much, & nbsp; that blow-off & nbsp; The thing is more beautiful, but I am wondering is this doing every gear? & Nbsp; Yesterday E-5 also made a car passed by me, but it was pretty fast, I asked the friend, every time he presses the clutch, he says it sounds like electronic or pressurized.
08.05.2020 16:35 # 3
bilmem26
blow off I searched for a little bit, there are electrons, you can get that sound between 150-200 rubles.
Reviews
08.05.2020 16:35 # 4
aspirinxlarge
I know that the gas cutting event is already there without anything stuck until the pedal of the vehicle is over when the cycle comes to an end.
08.05.2020 16:35 # 5
bilmem26
I do not have it in my car, I am pressing 7000e 7.5, no sound, no sound, no cutting, I do not understand, it was gone :)
08.05.2020 16:35 # 6
djchaos
I think the circuit breaker you have said, the needle on the tachometer enters the cutter just before it comes to the red line. In short, the speed limit that the gear you are in can turn. This limit is found to protect the engine, shifting before the breaker engages, prolongs the life of the engine
This limit varies depending on the engine of the vehicle, usually 1.6, 2.0 gasoline engines 6 thousand cycles limit djchaos 2012-02-12 20:29:27
08.05.2020 16:35 # 7
bilmem26
When I come to a certain period from most of the vehicles I am looking for, the sound that comes out does not come even though I say 7 thousand, that sound is so & nbsp;
08.05.2020 16:35 # 8
djchaos
If the car is lpg, I also know that the lpg cutter that I know will be canceled.
08.05.2020 16:35 # 9
bilmem26
I have LPG but I use it on gasoline, if I cancel it to get that sound, will it sound :))
08.05.2020 16:35 # 10
cerci07
Get it on the gas, load it until the end of the gas, you will get that sound soon.
08.05.2020 16:35 # 11
fTh206
http://www.youtube.com/watch?v=zaktz1kbgz0 you mean it is this
08.05.2020 16:35 # 12
bilmem26
Exactly this sound but does not it?
08.05.2020 16:35 # 13
fTh206
the gas should be pressurized until the end, but I think it would be better if you do not do anything other than damage the engine :)
08.05.2020 16:35 # 14
bilmem26
exhaust vs not required demi tool 106 xs & nbsp;
08.05.2020 16:35 # 15
fTh206
how is it going to sound without exhaust :)) there is a cutter in the car in that video also :) I couldn't understand what you mean?
08.05.2020 16:35 # 16
bilmem26
If you do not match what you say, you say what you say, my teacher will be in every vehicle. Does it matter whether you have an exhaust or not?
08.05.2020 16:35 # 17
fTh206
[QUOTE = I don't know26] you do not match what you say, my teacher.
08.05.2020 16:35 # 18
bilmem26
I asked how the cutter is, it is an extra blade or it will be the original peugeot 106 XSi
08.05.2020 16:35 # 19
aslan7333
The circuit breaker is available in all injection cars, some cut fires when the engine reaches the specified speed, some cuts the fuel, is related to the ecu software. .
08.05.2020 16:35 # 20
djchaos
friend do you have lpg in your vehicle? There is no breaker operation in LPG vehicles, plus it does not look too good for you. In a sense, the vehicle is shouting that the engine is stuck, you use your vehicle without forcing it. not the case) When it comes to the lpg event, a topic related to the lpg brain in the vehicle disables the breaker.
Page : / 2
