gas closed itself, the vehicle did not work :(
08.05.2020 17:25 # 1
mrb friends while traveling with my car today, when the city was stopped, the car stopped, I tried to start it did not work, the lamps of the gas did not go on, did not work, we took it to the nearest master, said the gas brain is defective, then we took the gas, the gas did not work in the car, the gas pump could be burned, left the car :( I would be happy if anyone who knows what it holds & nbsp;
08.05.2020 17:25 # 2
EnSoNiQ
the intention of some masters is not very good if you didn't leave the coach where you didn't know
08.05.2020 17:25 # 3
Barut
[QUOTE = EnSoNiQ] I wouldn't agree with some of the masters' intention unless you leave the car where you don't know [/ QUOTE].
08.05.2020 17:25 # 4
No, we left it to the knowing bio, but I don't know how it would be, the gas pump could be burned.
08.05.2020 17:25 # 5
EnSoNiQ
When my teacher's brain was broken, there was no gas in his car, he burned the pump, and if there was less than a quarter of gasoline in the car, it would not cool and burn the pump. The pump was a little strange when it could make the gas brain malfunction
08.05.2020 17:25 # 6
ahmet_bjk
Even if there are solutions to some problems, the masters do not bother, they run away and change the part.
08.05.2020 17:25 # 7
EnSoNiQ
The gas business is crippled or if it is not a proper brand, it makes the man struggle so much that his friend has eaten the gas pump.
08.05.2020 17:25 # 8
[QUOTE = EnSoNiQ] When my gas brain was out of order, there was no gas in the vehicle, if the car burned the pump, it does not cool if there is less than a quarter of the tank and burns the pump. The pump was a little strange when it could make a gas brain malfunction [/ QUOTE & nbsp;
yes, my teacher didn't have gasoline when I got out of the car, I looked at the finished bnde and kept it running & nbsp;
08.05.2020 17:25 # 9
There is an atiker on it, but I don't know, come on, gas was over in the car.
08.05.2020 17:25 # 10
EnSoNiQ
teacher, it is inconvenient to start when there is no gasoline in the vehicle, so you burned the pump for this reason. I don't know exactly how the brain burns.
08.05.2020 17:25 # 11
I think that there was no gas in this direction. The pump burned, but the electricity cut off from the gas stopped when it was going normally. There is no trace of the light of the gas. How much does the gas pump explode? mehmetmert16 2013-03-09 00:51:20
08.05.2020 17:25 # 12
EnSoNiQ
My teacher is a sponsor of our somewhat salty site, peugeot market & nbsp; 265 TL appears. target = "_ blank" rel = "nofollow"> http://www.peugeotmarket.com/206-14-BENZINLI-FUEL-PUMP-MOTORLU,PR-582.html
< editID> EnSoNiQ 2013-03-09 01:15:20
08.05.2020 17:25 # 13
_PunisheR_
this is the complete one. there is a part in it they change it my car 1.6 i bought it for 60 or 65tl max 2 months ago
08.05.2020 17:25 # 14
_PunisheR_
[QUOTE = mehmetmert16] my opinion is that there was no gas in this direction, the pump burned, but the power cut off from the gas stopped when it went normally, but there is no trace of the light of the gas. [/ QUOTE]
my lpg brand aiker and there is a power cable coming to the battery when the light comes out, the light on the gas indicator goes off and naturally the car does not switch to gas, could you have something like that?
08.05.2020 17:25 # 15
Yes, there is a cable from gas to battery, there is a flange, & nbsp;
08.05.2020 17:25 # 16
265 too salty or building for now. It is the ghetto piece that your friend is talking about.
08.05.2020 17:25 # 17
_PunisheR_
[QUOTE = mehmetmert16] 265 too salty or build for now. I do not think it will be a complete pump & nbsp; [/ QUOTE] problem. check the cable and fuse going to the battery in gas
08.05.2020 17:25 # 18
cable from gas to battery was checked, even no problem in the fuse.
08.05.2020 17:25 # 19
_PunisheR_
I don't understand how it stopped + how it stopped.
08.05.2020 17:25 # 20
Here are some incompatible people. Let's look at something that happens when the vehicle is in motion. I will go to the vehicle for 1 hour. no problem happens
Page : / 2
