Gas butterfly
08.05.2020 15:29 # 1
emntstn
my car burns a lot. 13% local, 8% intercity. I want to clean the throttle myself. Tonight I wiped the pipe from the air filter to the throttle. do we need calibration? Also, will fuel consumption decrease as a result of this process?
08.05.2020 15:29 # 2
106_arts
There is a subject I told with a picture that I am hurt, you can look at it
08.05.2020 15:29 # 3
Generally enough. If you did it, you will not notice a difference. But the spark plug is the air filter, etc. Have you done the necessary maintenance ???
08.05.2020 15:29 # 4
106_arts
http://forum.peugeotturkey.com/forum_posts.asp?tıd=15035&pn=1&title=206307c3c4xsara-16gaz-kelebei-skm-temizlik
08.05.2020 15:29 # 5
emntstn
spark plugs, filters have changed. solenoid valves and transmission oil have changed. software has been renewed? i am trying to find out why it burns so much. i would be glad if you help ...
08.05.2020 15:29 # 6
tool connected to the computer ??? What is km ???
We've caught it over time and the converter can become clogged. how are you doing ???
08.05.2020 15:29 # 7
emntstn
They did not say anything at the service, the vehicle is at 98000. The traction seems a little weak. But the vehicle is triptonic, I hooked it.
08.05.2020 15:29 # 8
It is difficult to comment more without seeing the vehicle.
08.05.2020 15:29 # 9
emntstn
thank you for your information.
08.05.2020 15:29 # 10
106_arts
How do you say when the software is renewed?
Who did this renovation work?
08.05.2020 15:29 # 11
emntstn
authorized service, gearbox and engine computer updated
lüleburgaz ariner is in service.
08.05.2020 15:29 # 12
In this forum, I had solved the problem under the title of "I am in bad condition" by removing the ratio ... officially turned into a pink series .. its back like tomorrow Sırıtma Grab it from the ignition coil, tiriger set .. Grab the gearbox without lowering it, from the air filter assembly, from the sibob setting to the engine air discharge pipe.
08.05.2020 15:29 # 13
106_arts
What is this update price _?
08.05.2020 15:29 # 14
emntstn
I changed the solenoids, changed the gearbox oil. They made updates with them. All kept 425 TL.
08.05.2020 15:29 # 15
emntstn
by ersin so which one did you solve this problem? what kind of a reduction in fuel?
