Gas & Lpg
08.05.2020 19:26 # 1
Htc
The car with the Peugeot 206 1.4 xr automatic LPG did not work about a month ago. It worked when we put and started running petrol with no fuel left. Confused I always use LPG, does anyone know why gas is running low? I wonder if it is only when we start using gasoline? This comes to my mind. Confused
08.05.2020 19:26 # 2
In-line system vehicles, like yours, operate on gasoline until the engine temperature reaches a certain degree. there is no problem, but try not to drop the gasoline under the quarter tank or the gas pump may fail.
08.05.2020 19:26 # 3
Htc
Thank you for your reply. After that, try not to fall under the quarter warehouse.
08.05.2020 19:26 # 4
talip206
Since our vehicles are lpg system, they run on gasoline in the first run, then automatically switch to LPG when the engine reaches a certain temperature. In summer, this period is short, while in winter it takes longer to lpg. Do not fall below the quarter tank so that Soner does not burn the gas pump as your friend wrote.
08.05.2020 19:26 # 5
Htc
Thank you, good forms.
08.05.2020 19:26 # 6
oguz41
If you want to increase the amount of 10 TL, we will chronically drop the needle in our vehicles since it is connected to the computer. Increase the amount of 10 TL, see where the hand will come. Of course, the gasoline will be gone, since the vehicle consumes gasoline every time it starts.
