gap in the steering wheel
08.05.2020 17:38 # 1
206 ersan
friends have a little gap on the steering wheel of the car does not bother much, but the steering wheel is very light on the left, they set it with a tire on the left side, but the man adjusted it flat but maybe it feels even more if the speed of 120 is coincided, but it is not possible to make a speed in the city. There was a gear 2 months ago, a repairman said so, but I do not have it open.
08.05.2020 17:38 # 2
qqyyxx
bro, does the car go to the left or right, even though you keep the steering wheel straight on the straight track? If that was meant the rot setting was bad. You can have a tie for 20 TL.
08.05.2020 17:38 # 3
206 ersan
[QUOTE = qqyyxx] bro? Does the car go to the left or right even though the intersection is keeping the steering wheel straight on the straight track? & nbsp; If this meant, & nbsp; your rot setting was broken You can get a tie rod for 20 TL. I put it in cm rotary rod adjustment, no problem, the front of the car is not in any new shaking or pulling.
08.05.2020 17:38 # 4
he was in my old car too. I think you are uncomfortable with the image. it doesn't cause any other problem.
08.05.2020 17:38 # 5
206 ersan
There is no problem, according to the slope of the road, you can play more with the steering wheel thanks to the gap on the steering wheel and when it goes fast, I think it may be dangerous, I think it may be dangerous.
08.05.2020 17:38 # 6
If there is a lot of space, show it to the master. It doesn't matter.
08.05.2020 17:38 # 7
ismailkaya
I think you can tighten the screw on the accelerator pedal to one of the master or you look again
08.05.2020 17:38 # 8
206 ersan
[QUOTE = ismailkaya] I think you tighten the screw of the gas pedal there, or look at one of the master or more often [/ QUOTE] When I say the gas pedal is there, I have a screw close to the gas pedal in the steering box
08.05.2020 17:38 # 9
vbmaster
I mean, the chassis below means the screw ...
