fuse box
08.05.2020 20:21 # 1
Silverballer21
friends, the fuse of the gas pump is constantly throwing, what can I do
08.05.2020 20:21 # 2
sdttn
Just in case it is connected to that fuse canister valve, it should be determined whether the problem is in the pump or canister valve by disconnecting the canister valve cable. Pump and canister valve installation should be visually inspected.
I will help you better if you give the motor code exactly.
The canister valve is something like this on the passenger's side under the hood.
sdttn 2017-05-21 22:09:50
08.05.2020 20:21 # 3
Our friend has to make the necessary explanation, it is necessary to control the electrical installation and sockets well.
08.05.2020 20:21 # 4
Silverballer21
thanks bro we are on watch now tomorrow i will see immediately
