fuse aid
08.05.2020 15:14 # 1
phaselispa
hi guys today i wanted to run the boiler. the indicator works normally but does not blow air. When the air conditioner turns on, the air conditioner comes into play, but it does not blow air again.
I opened the fuse board, but there are numbers that start with plain f. There are no shapes like this on the top.
do you have any of these shapes or what else could be the problem.
08.05.2020 15:14 # 2
Peugeot 206 icin:
Sizin durumunuza F40 uyuyor, bir kontrol edin bakalim.
Passenger compartment fuse box (BH 12)
Fuses
Rating
Supply
Application
F29
10A
High beam
Left high beam
F30
10A
Right high beam and warning lamp
F31
10A
Low beam
Left low beam
F32
10A
Right low beam and warning lamp
F34
10A
+ side lamps
Front left side light, left tail lamp
F35
10A
Front right side light, rght tail lamp
F36
+ve after ign. off
Free
F37
5A
Coolant temperature unit
F38
5A
Fan, pressostat
F39
Free
F40
20A
Ventilation/heater blower (without AC)
F40
40A
Air conditioning blower.
08.05.2020 15:14 # 3
phaselispa
thanks buddy let me check
08.05.2020 15:14 # 4
[QUOTE = phaselispa] thanks dude let me check it out [/ QUOTE]
It is usually driven along with the fan role and must have these roles in the fuse panel. If you can't get results from insurance, you need to see if there is current in the insurance. If not, it is the role.
Note: The vehicle must be running when checking the current.
Koliva 2011-04-07 23:12:43
08.05.2020 15:14 # 5
kaan__
you probably were using digital calories not from the sigota tray, the calorie engine was disassembled or disassembled (green circuit) the card in the card probably burned, the electronics electronics (not electrician) repairs the same thing happened to me too, suddenly I started to blow air went to the service they said it would change 350tl thanks electrician friend directed me 40 I got it to tl it is very likely that you have the same problem
08.05.2020 15:14 # 6
[QUOTE = kaan __] you probably were using digital calories, not from the sigota tray, some places were burnt to the card inside the disassembled or disassembled (green circuit) electronic electronics industry (not electrician) repairs the same thing happened to me suddenly it started to blow air, they said they went to the service, they said they would change 350tl thanks electrician friend would take me 40 tl I took it very likely very likely you have the same problem [/ QUOTE]
This is the worst scenario. On the way to Cozume, you need to start with the easy things first. Get well soon.
@ phaselispa : Check F38 while checking.
Koliva 2011-04-07 23:18:28
08.05.2020 15:14 # 7
kaan__
Actually, as you said, but they did not even look at the insurance, it was usual in the service, I hope they said that they had been in a few cars before, but it is not something to try to get a new recommendation from me.
08.05.2020 15:14 # 8
phaselispa
I hope it is only from insurance ...
08.05.2020 15:14 # 9
kaan__
Even if it is from the engine, it will be very easy to wear. I was so cold for 2 days :))
