full sound from the right front wheel
08.05.2020 19:48 # 1
vpro
Good day to you guys.
After replacing the winter tire, a "full" sound comes from the right front wheel. It sounds like the shock absorber is dislodged. Sometimes thought comes into the pit. Sometimes it comes while turning the steering wheel while standing. The most prominent is that after loading the gas in 1st gear, when I suddenly pull my foot off the pedal, it sounds as if it is "full", as if the engine ear is old.
What do you think is the problem, guys?
08.05.2020 19:48 # 2
Cyrus35
Get well .. I have the same problem with me brother bro if I find one LOL
I changed from previous axle head in my previous vehicles, it was improved.
In another car, I started to hear a similar sound, they said the axle changed, but it did not improve podye (Wheel bearing) changed, it improved. For your information, I am researching the current one, let's see where it comes from. Angry
08.05.2020 19:48 # 3
vpro
shock absorber mount causes such a sound?
When the vehicle is stationary, when turning the steering wheel, there is a voice called cır cır.
vPro 2016-05-15 10:22:09
08.05.2020 19:48 # 4
Dadas-25
right, the table will change, my brother, I changed 60 TL, I gave 30. lira master craftsmanship.
08.05.2020 19:48 # 5
vpro
[QUOTE = Dadas-25] the right table will change, my brother, I changed 60 TL, I gave 30. lira master craftsmanship.
Did you hear any noise while driving?
08.05.2020 19:48 # 6
Dadas-25
If you hear an annoying sizzling when the car turns the steering wheel with a stop, the chances of having a screed are also very high. Also, take a look at the hydraulic oil. DaDaS-25 2016-05-15 21:57:26
08.05.2020 19:48 # 7
vpro
[QUOTE = Dadas-25] If you hear an annoying sizzling when your car turns around with the steering wheel stopped, it is very likely that there will be a screed, and also take a look at the hydraulic oil in the steering wheel.
he has to look at the wheel, then the master comes from somewhere, he goes to the hole
08.05.2020 19:48 # 8
Dadas-25
I say, look at the table at a suitable time.
