Fuel pump runs loudly
08.05.2020 16:57 # 1
woshborn
Hello guys, when I got in my car today, there was a sound from the back seat. Gas pump under the back seat where the sound comes from works loudly.
the vehicle is running at the first contact no problem
207 1.4 2 tronıc
I have brc lpg in my car if you think my petrol filter is clogged or if my gas pump has failed, I would be glad if you can give information ..
08.05.2020 16:57 # 2
Serkan
Sir, we had an opel, we had the lpg installed, while the LPG was being installed, the car was put on the role to prevent the gas pump from working while working on LPG, our master forgot to put the role and tried to send gas to the engine on the gas pump while the car was working on LPG. then it broke down. Check while the vehicle is running at lpg. Is the gas pump activated?
08.05.2020 16:57 # 3
woshborn
thanks for the info & nbsp;
but there is only sound everything else works normally & nbsp;
08.05.2020 16:57 # 4
seyhanak
This is the sign that the gas pump will burn as soon as possible!
08.05.2020 16:57 # 5
Serkan
[QUOTE = woshborn] thanks for the info & nbsp;
but there is only sound everything else is working normally & nbsp;
My teacher go to the gas pump in my opinion It is about right now it is working right, but something will come out over time. I hope it will not matter anything
