Fuel problem..I am in trouble :)
08.05.2020 15:23 # 1
cesva25
friends I bought a 306 1.6 manual 2001 model pajom with the permission of god .. i am very satisfied .. i was single bored .. 600 krş yakıo and also in calm use delircem .... the process I did not do in front of the car did not remain .. oil water butterfly throat cleaning injecion cleaning injecions sibob adjustment pejocuda I connected it to the pc, there was a problem of idling, it was even done .. I even reduced the gear :) I even reset the front set completely .. I made a cost of 2.100 TL. there is a pipe that comes right, the tip is like a duck mouth .. i don't have it .. there was an open air filter .. i disassembled it again .. now i ordered that air pipe i will put it on the original let me burn it again .. help me in this matter .. otherwise I will pour the gas and burn it :)))
08.05.2020 15:23 # 2
Muhammet CAKIR
It is normal, brother, the liter of gasoline is over 4tys :) When it is 1.6 in the engine, it will not be forgive, but if you are going to burn 600 cents too much, using petrol is very expensive. Sırıtma
08.05.2020 15:23 # 3
cesva25
:)) What about that joke :)) I'm Napcam? Do not say lpg :)) but 306 timbre does not have that acceleration, do not think of the fuel while at the wheel :))) Do you think it is normal to burn 600 krş.
08.05.2020 15:23 # 4
metin
cevsa25 will be better if you make the following fuel calculation in liters because the gasoline prices are constantly changing accordingly, the fuel increases but the liter that the vehicle burns at 100 km does not change, so it is easier to calculate. Anyways
The vehicle burns 13.95 liters per 100 km, which is very high. Even my car 307 1.6 auto burns 10.7 liters. I guess it should burn 8-9 liters instead of 13.95, so you should burn between 0.34 TL and 0.39 TL.
By the way, did you show the thermostat, may it be defective? The fuel had dropped about 2 liters when I replaced it while it was defective.
If you are wondering if it is not malfunctioning, let's see if the temperature is between 90-95 degrees or it goes above or below me. Because the vehicle burns best above 90 degrees, if the engine remains cold, the fuel will increase if the temperature is always low.
08.05.2020 15:23 # 5
[QUOTE = cesva25] :)) or what a joke :)) napcam me? Do not say lpg :)) but do not think that the 306 timbre has no acceleration, do not think about the fuel while at the steering :))) Seriously 600 burn it for you ... Who knows if the area is greasy:)) [/ QUOTE]
why are you tightening the tool too ??? or do I wonder if I have a neglect?
60 km per km means 14 LT per 100km Göz Kırpma
the cecol 2011-05-04 11:15:25
08.05.2020 15:23 # 6
tigerland
are you sure that your calculation is correct? How did you detect that it burns 60 Kr room is important
08.05.2020 15:23 # 7
cesva25
TEXT SOMEONE NO TELL ME TELL ME AAAAAAAAA..I'm amazed YES .. I DO NOT USE THE SHOULDER MOVEMENT INDICATOR, I CHANGE THERE. OR IT SHOULD BE UNDER THE BEAT, AND THAT IS THE DAMAGES OF NOT LISTENING TO THE BIG ORDER .. OK, I'M REPLACING THE CUSTOMER WITH THERMOSTAT. GASOLINE INSIDE ABI :))
NOW THE QUESTION IS .. THERE ARE THERE ARE THERE ARE THERE ARE THERE ARE THERE ARE THERE ARE THAT YOU CAN RECOMMEND THAT ARE YOU ARE TO RECOMMEND ... THAT I WOULD LIKE TO SEE THIS ...
08.05.2020 15:23 # 8
cesva25
ABI I TAKE 50 TL GASOLINE GAS RESET KM I GET RESET IN 80 KM GASOLINE LIGHT YANIO :))) CALCULATE ... BUDDING MAKES 0,625 CROSSS.
08.05.2020 15:23 # 9
metin
[QUOTE = cesva25] TEXT SOMEONE WHO DIDN'T TELL ME THIS AAAAAAAAA..I'd be surprised YES .. I SHOULD I SHOULD I CHOOSE THE SHAPE HARREET INDICATOR. OĞLUM BAK, THIS MOVEMENT SHOULD BE BELOW 90 YEARS, BECAUSE IT'S DAMAGED .. HERE IS THE DAMAGE OF LISTENING TO THE LARGE WORD .. OK I'M REPLACE THE CUSTOMER WITH THERMOSTAT. ) LIKE CONTAINS WATER AND GASOLINE DRINK ABI :))
Estafurullah.
The thermostat normally keeps the temperature of the engine at 90 for 307, of course. I don't know how many 306's should be.
For example, it is from the construction thermostat, although my calm use was not lower than 13.5, the temperature was always 60-70 degrees, so the engine always worked in a rich mixture to catch 90 degrees and the fuel increased. Thanks to cem bro, I realized that I went and changed it and now it is down to 10.7 liters.
Also, the problem may not be from a simple thermostat because if it is defective, I guess that if your vehicle burns 5 liters more when it is replaced, it will drop 2.5-3 liters. Let's share the result with us.
08.05.2020 15:23 # 10
There is no problem in your thermostat, my beautiful brother :)) you will be looking for other places. Have you looked at your spark plugs? you need to look at the lambda sensor of the vehicle. Because of this, it can be very burning.
What is the km of the vehicle ???
If the text remains hungry, it means the engine is sogur. If you want to change the thermostat, it will work in the same way. Normal between 90-100. I will work more broadly according to yours. Between 85-100 ...
08.05.2020 15:23 # 11
[QUOTE = text] [QUOTE = cesva25] TEXT SOMEONE NO TELL ME THIS. AAAAAAAAAA..I'm surprised. .. BUT MY FATHER SAID MY SON LIKE THIS MOVEMENT SHOULD HAVE BEEN UNDER 90 YEARS, BECAUSE IT'S DAMAGED .. THAT'S THE DAMAGE OF LISTENING TO THE LARGE WORD .. OK, I HAVE THAT I HAVE REPLACE THE CUSTOMER WITH THERMOSTATE. SUCK ME AND STOP :)) LIKE CONTINUES WATER AS GASOLINE DRINK ABI :))
Estafurullah.
text, we solved your heat with a thermostat, but not everybody will say the same thing. I don't have a cold in the car of your friend :)))))
You are telling everyone about the thermostat, but wrong, do not direct it :) Ask me if I have a cold first, no need to handle the thermostat :))))))))
08.05.2020 15:23 # 12
cesva25
HOPBALAAAAAAAAAAA .... I HAVE CHANGE THE SPARK PLUGS WITH ZERO ORIGINALS ... I WILL CHANGE THERE ... THEN I WILL CHANGE THERMOSTAT. I HAVE USED THE FIRST STEP RENO ON THIS DAY. I HAVE PASSED THE FIRST STEP IN PEJHOD .. BUT THIS FUEL IS A PROBLEM. ... BUT IT COMES TO THE GENERAL .. CECOLI DID NOT UNDERSTAND IT TO THE LAMBAR SENSOR OF YOUR VEHICLE ??
08.05.2020 15:23 # 13
monur
206 1.6 16v 110 automatic gearbox, I filled the last half tank, I filled the gun at 99 TL and completed it to 100 TL. Today, at the point where I bought full gasoline, it made 257.5 km. In this case, there is 0.388.3 km consumption. I will calculate it in liters.
08.05.2020 15:23 # 14
cesva25
MORE THAN 132 THOUSAND ... ORIGINAL ..
08.05.2020 15:23 # 15
metin
If you read cem brother carefully, I asked in the first message that I am already under 90-95 degrees.
1. If you are wondering if my message = not malfunctioning, let's see if the temperature is between 90-95 degrees or it goes far below or above me. Because the vehicle burns best above 90 degrees, if the engine remains cold, the fuel will increase if the temperature is always low.
In my 2nd measj = also, the problem may not be from the simple thermostat because if it is defective, I guess that if your vehicle burns 5 liters more, it will drop 2.5-3 liters. Let's share the result with us.
I did everything but did not write the reverse osmosis, I am trying to help as much as I know.
08.05.2020 15:23 # 16
cesva25
I will buy this thermostat how much someone will buy it and immediately start the process ... and share the result with you ...
08.05.2020 15:23 # 17
metin
cem is using the monument 306 but its engine is 1.8. I don't know if there is a thermostat difference here.
08.05.2020 15:23 # 18
thermostats are different anyway. 1.4 and 1.6 are the same, 1.8 and 2.0 are the same :))
08.05.2020 15:23 # 19
cesva25
I understand ... in this case, I'll buy a thermostat of 89 okay ... thank you .. inşşalh event solved ...
08.05.2020 15:23 # 20
nurinuri58
Friends can I have a bidet to answer my question. I bought the new 2006 model 206 car 1.4 engine with 102 hp tube. There are 205-40-16 wheels and tires on it. It is said to affect fuel. I wonder how much it affects. The city is making 210 220 km of road with a 50tl tube. But I am in the district, it does not stop very quickly. It is like an average of 240 cents per km. how do you think
Page : / 8
