Fuel Problem and Flicker While Accelerating, Start Stop
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
08.05.2020 21:22 # 1
efbiey
Hello. Last week, I bought the 2016 model Pegueot 2008 1.2 Puretech Allure 110 Hp Eat6 S&S. I will be very happy if you answer some questions.
1. The start stop of the vehicle does not work very stable. Some days are working some days are not working, what could be the reason?
2. The fuel consumption value of the vehicle was too high. Even in very calm use, it burns an average of 7 -8 liters. Also, the consumption value varies continuously between 1 Lt and 14, 15 liters even at a constant speed. How normal is this? (video: https://streamable.com/i61jl )
3. While the vehicle is accelerating, it accelerates with vibration, is this normal?
Thank you already.
08.05.2020 21:22 # 2
First of all, welcome to us. I wish you to use your vehicle without any accident, good luck. 1.2 purutech some series had a manufacturing error. spark coil was improving and updating the software sometimes even those with zero engine made changes in turkey. I know that there is a direct revision engine replacement in Europe. If your vehicle is authorized, it is useful to take it. s & s have working principles cold weather etc. affecting. of course your battery condition is also important, but it is usually caused by the battery. If the original battery is on your vehicle, the problem is probably the battery. I have rarely seen this type of complaint so far in eat6 fully automatic chassis. axle control, tire condition should be checked.
08.05.2020 21:22 # 3
efbiey
The vehicle is at 39,000 km. Is it normal for fuel consumption to show up and down like in the video?
08.05.2020 21:22 # 4
Fikretalbay
Hello, I have 2008 1.6 Blue too. Strat / stop stopped working before reaching 15000 km. They replaced the battery in maintenance. It returned to normal. I'm going to be in maintenance at 30000 right now, but at 25000 Start / stop stopped again, just the light is flashing. Will the battery change again? I do not know.
08.05.2020 21:22 # 5
bsencan
Hello Fikret
I also have 1.5 allure. s & s does not work if the vehicle engine is cold in start stop. or if the engine is hot but the heater is on, s & s will not work again. Other than that, it works fine in general.
