Fuel problem?
08.05.2020 20:27 # 1
deuve
Hello, I bought my car in 97 thousand kilometers of used cars. When I bought the filters and linings had to be changed, I made the necessary procedures but it caused a problem like this; When I bought the car, it showed 6.3 as the average fuel, but now it does not drop from 8.3, so I am not someone who presses the gas and uses it aggressively. I have not even seen 3 thousand cycles for 1.300 kilometers :) I don't think these fuel values are normal, as a result of my light research on the forum and on the internet, this figure is huge. I am very curious about your opinions and ideas on the subject, I would be glad if you share it with me. Also, if you know a reliable solid master around Beyoğlu, I would like to show him the tool.
Thank you very much in advance, I wish you a good day.
08.05.2020 20:27 # 2
First of all, welcome to us. vehicle diesel or gasoline
08.05.2020 20:27 # 3
deuve
I found it nice, sorry, I forgot to mention. The vehicle has a diesel and semi-automatic transmission.
08.05.2020 20:27 # 4
Well, you can see those values in the city. the reason for this is to stop too much - short distance usage - the fuel you buy - the neighborhood where you live is very hilly - the filters used are sub-industries. In addition, do not use at low speed continuously, occasional aggressive will be good for the health of the vehicle.
08.05.2020 20:27 # 5
uzunca961
The only reason to see those numbers is because of the excessive traffic and the slope. When my husband gave birth, he had seen fuel 7.9 at the hospital. By the way, we have the same vehicle. mine 2010 comfort. so it is likely to be 8.3.
As the soner says, take the car from time to time and use the car at high speeds. The reason is the particulate filter. These vehicles have a particle filter and filter the dirt in the exhaust, preventing it from being thrown out. When the vehicle is running at low speeds, this filter is constantly filled and not cleaned. The smoke coming out of the engine at higher speed becomes warmer, more pressurized and this ensures the cleaning of the filter.
As a note, let me note that they clean the gas at 3500 rpm for 15 minutes to clean it. We can only do this on the long road, because there is no lift.
uzunca961 2017-07-12 07:59:51
08.05.2020 20:27 # 6
deuve
Thank you very much for the information, let me try it at high speeds for a few days. As you said, I usually use the vehicle at short distances, then it may be caused by it. Thank you again, I wish you a good day.
08.05.2020 20:27 # 7
uzunca961
[QUOTE = deuv A] Thank you very much for the information, let me try it at high speeds for a few days. As you said, I usually use the vehicle at short distances, then it may be caused by it. Thank you again and have a nice day. [/ QUOTE]
Hodja also, you do not need to use it at high speed continuously. occasionally 3 4 months maybe
