Fuel Problem
08.05.2020 18:22 # 1
sahbazx1
First of all Hello, I just joined you, yasin, I live in İzmir.
Last month, I bought a peugeot 206 1.4 x-line red car. I want to consult you on this subject.
Friends My car's gasoline fuel pump had a crack in the float part. At that time people around me said that the car had burned too much.
To say the available data;
Around 40 krş on the long road,
In the city, my car burns 50 krş (sometimes 55 krş).
Do not you think these numbers too?
I may be using a little bit of a cycle, but it shouldn't burn that much.
Thank you in advance for your answers . Regards ..
08.05.2020 18:22 # 2
ahmet_bjk
Have a good vehicle. Welcome aboard.
I will not know if it is normal because I use diesel, but you can calculate whether it is normal or not.
You can calculate how much LT fuel your vehicle burns and compare it with factory data. It is normal for 1 LT to be too much.
Also, if you are driving the car, it burns more than usual.
08.05.2020 18:22 # 3
ErdiCoskun
1.4 vehicles burn more than 55 cents. my 1.6 110 liter vehicle shows 10-11 liters per 100 km at 13km / h on the on-board computer in the city, so 50-55 lira is the same as your vehicle. I suggest you do a 10,000 maintenance of your vehicle,
08.05.2020 18:22 # 4
Serkan
It varies according to the road and distance you use, if you are driving at a short distance, it is normal value for the city, but if you use it at a long distance, the speed values are important for out-of-city consumption.
08.05.2020 18:22 # 5
sahbazx1
The traffic of Izmir is a little cramped. So, the stop-and-go event is very high.
08.05.2020 18:22 # 6
Barut
I use the same engine in the city, it burns 50 55 cents in the city, I burn around 30 cents out of the city ... 206 1.4 gasoline burns a lot, whoever says whatever he drinks 1.4 gas.
08.05.2020 18:22 # 7
ahmed206
If it is automatic, it would burn more and manual gear 1 shirt down. There is also a difference from user to user.
The factory values are not very high after all. I also had 30 cents on the same road, and I had 50 cents. But after I started to see instant consumption on the trip computer, I always pulled down consumption consumption.
08.05.2020 18:22 # 8
kursat3006
In my opinion, don't be too tired for a normal gasoline car
08.05.2020 18:22 # 9
bjkamil
like normal in winter. 10lt / 100 km according to trip computer, 8lt / 100 km in summer. I go to work every day 10 km round trip
