fuel needle problem help !!!
08.05.2020 17:24 # 1
alp2525
Yesterday, my 407 diesel vehicle tank was close to the fule yesterday, I said I would buy a diesel again. I bought a fuel for 45 TL, but the fuel needle was standing in the same place before buying a diesel. I traveled .40 km, I fullet again from another station, but the pointer showed the same level again.
I disassembled the poles of the vehicle
I plugged in the socket of the float
but still the same problem still continues.
08.05.2020 17:24 # 2
plawert
there is a possibility of recovery when connected with the device and a coding
08.05.2020 17:24 # 3
blinddark
the same thing happened to me, I always get the fuel from opet, but when the vehicle was in my father for 1 week, I was worried about the problem with the PO and the best hand, but I was worried about the problem the next day when I went to work the next morning, the needle came back to normal, but sometimes I could work late in my car. sometimes there is a problem, float automatics is expensive, I couldn't change it, but I had it cleaned sometime
08.05.2020 17:24 # 4
alp2525
teacher, I just tried to disassemble the socket, plug it in, fill it up to the warehouse throat, go and fill it, I said it took 5 TL, but it popped up to the pipe, I filled it up to the pipe, but the problem still continues, but if it is defective, I say it will not work, but let's look at the last quarter in front of the full house. Will yours still recover or do you need to clean the float ??
08.05.2020 17:24 # 5
Serkan
Sir, use the tank until it is less than half, then the fuel will recover, it happened to me several times.
08.05.2020 17:24 # 6
blinddark
[QUOTE = alp2525] my teacher just tried to disassemble the socket, put it on the tank, filled it up to the throat, filled it, I said it took 5 TL, but it popped up to the pipe, I filled it up to the pipe, but the problem still continues, I think it will not work if it fails, but it stops at the last quarter in front of the full house. Let me use it a little bit, let's see, maybe it will improve, is yours still going on or need to clean it? After I cleaned the float ?? [/ QUOTE]
I did not have a lot of trouble but when I filled the car 307 diesel, I did not come to full line. If we consider the warehouse needle as a 100% share, the first quarter is 25% the second quarter (half tank) 50% the third quarter is 75% and the full part is 100% whenever I fill the tank when the needle is max. It stands in the middle of 75% and 100%
08.05.2020 17:24 # 7
alp2525
Let me use it until halfway, it seems like it will be recovered.
she had never done this before
08.05.2020 17:24 # 8
webbee
If you have the opportunity to shake the car halfway through the tank, shake it is stuck on the samand. This does not mean that it will not be done.
08.05.2020 17:24 # 9
mistik
the same thing happened to me, the light went on, I entered the petrol, filled the diesel, looked the light is still on, I said my pump was broken, the same was filled .. .. but on the evening of the next day I contacted the needle fulledi suddenly :) rust dirt bits were installed, then cleaned afterwards :) did not do it again .. add fuel additives if there is some dirt or something.
08.05.2020 17:24 # 10
Mavericks
Hello guys,
I bought fuel this evening. They put a 30-liter diesel in the car without turning off the ignition, because there were children (2015 model 301 Active 1.6 HDi 92hp). When I looked back, I called the officer when I realized that the needle did not move. He said that the float was stuck because the car was running and it would be fixed when the ignition was switched on and off. Anyway, I immediately researched the subject, but there are a wide variety of comments. According to one comment, I added another 10 TL of fuel, but the float did not improve.
How will this be improved? Thank you very much for your help.
08.05.2020 17:24 # 11
bariszeynep
I guess I think the problem of all lions is mine
206 and now there are 307 hdi even under 50 fuel needle
Unfortunately, it doesn't play
08.05.2020 17:24 # 12
Mavericks
When I take 30 TL, two or three teeth go up accordingly.
08.05.2020 17:24 # 13
gecegoz
The float in our vehicles is electronic, it gives different
omage when it is full and empty, and BSI has an existing value, > and it will fail in a short time,
If you leave the 1st or 2nd pump shot while filling, your float will provide a long-term healthy operation of
. If you encounter, finish your tank halfway and do not fill in full ...
08.05.2020 17:24 # 14
Veysell
Hello brother, your car's fuel needle is okay, just connect it to the original service device and calibrate the instrument panel, it was enough for me.
