Fuel Indicator Problem
08.05.2020 19:37 # 1
seamad
Friends yesterday I bought my vehicle and I parked my car in the morning when I started my car, the diesel light turned on, the warehouse was showing zero, I went to the nearest station, I bought diesel to try 20 TL, the hand did not move again, I want help from friends who have such an event or know about the subject.
08.05.2020 19:37 # 2
float fitted :) most likely
08.05.2020 19:37 # 3
seamad
What do you think Soner should do? I do not want to go to industry in this weather, I came to the office hard :)
08.05.2020 19:37 # 4
They are usually disassembled and cleaned. :)
08.05.2020 19:37 # 5
seamad
Brother, I bought a 50 TL diesel, played a needle, I bought a total of 120 TL diesel, so the light was on when I first bought it, it was normal, I guess, I went to the industry. .
08.05.2020 19:37 # 6
the float is stuck so you bought little fuel :)
08.05.2020 19:37 # 7
seamad
It was a little bit like that :)
08.05.2020 19:37 # 8
talip206
You need to get at least 7 liters of fuel for the needle to play. Unfortunately, since fuel is very expensive in our country, we give so much money and move the needle hard :)
08.05.2020 19:37 # 9
seamad
In other words, when it came on the road, the needle fell again, there is more diesel than the tank at the moment, but the needle shows a quarter :(
08.05.2020 19:37 # 10
Gokcesel
Your Hebrew may also be corrupt. Personally, my temperature and diesel shows less than it is. :) At the moment, the pointer has not illuminated under red. the trip computer says that with more than 150km go :) Gokcesel 2016-01-21 20:12:10
08.05.2020 19:37 # 11
Mesut48
Did you refuel with the ignition on?
There is nothing to worry about,
When the fuel lamp is on, I say at least 7-8 liters.
In Clio4, it happened to me, when the contact is open in half tank, the needle is stuck,
After going down to half a tank after usage, the fulledic problem was solved.
Maybe the problem is the same problem, after all French :)
08.05.2020 19:37 # 12
Fthz
My vehicle also received 50 TL, it does not change the needle when it gets fuel, both a coy and a crafty vehicle peugeot Big smile
08.05.2020 19:37 # 13
by_oknkck
Friends is the definitive solution; The tank of the 307s is 60 liters as is known. The fuel section in the instrument panel consists of 8 compartments. This means that, on average, each compartment means 7.5 liters. The reader of your float does not give fuel information to the brain of the vehicle when you buy less than 7.5 liters, so even if the in-tank float rises, the needle of the fuel section on the instrument panel does not move upward. This means that, since your vehicle cannot calculate the fuel you have received, it keeps the needle in the same place and guarantees itself by keeping the fuel in excess in the pocket by not calculating it, rather than misleading you about fuel. In other words, your problem will be solved by purchasing a minimum of 7.5 liters of fuel for the vehicle to be built. If it still continues, or if more liters are fixing the problem, you can go to a good electrician while removing the float and solve your problem when the tank is near waste. I have solved this information on this issue a lot.
08.05.2020 19:37 # 14
seamad
Thank you for your answers, I am waiting for the diesel in the warehouse to be finished.
08.05.2020 19:37 # 15
timo206
it happened to me sometime, the buoy is stuck, the tank is full, I think the dirt is stuck in the corner, there is already a very sensitive mechanism, even if the needle tip is clogged,
