Fuel increase after lpg filter change
08.05.2020 16:17 # 1
assat76
Hello friends.2 days ago, I renewed the filter of my atiker brand. As the gas setting, only degree 27 was made and the pressure was pulled from 0.65 to 0.50 so much, but today I tested it. I made 70 km with a 9.6 liter gas. automatic, but it never burned like that. Some friends said the fuel increase when the first filter is changed, but I asked the master, come on tomorrow, let's see, he said we never played with his setting. previously it was burning 20 krş or something in the city now it is almost 38 krş "Grin"
08.05.2020 16:17 # 2
assat76
friends no answer?
08.05.2020 16:17 # 3
alisuat
I think it is normal test a little more.
08.05.2020 16:17 # 4
teacher, I changed the filter, it seemed like it happened to me I will say the exact result when the warehouse is over, but as I have watched from the lights, it did not go off before 110 km before the first light went out at 90 this time. let's see what the result is, I just made the degree adjustment, I didn't do anything else
08.05.2020 16:17 # 5
assat76
[QUOTE = htasay] teacher, I changed the filter in me, it seems to me that it is now. I will say the exact result when the warehouse is over, but as I have watched from the lights, it did not go off before 110 km before the first light went out at 90 this time. let's see what the result is, I just did the degree adjustment, I did not do anything else [/ QUOTE]
my teacher, your good is turned off at my 65, I said the first light noluyoz "Embarrassed" I made the grade 25, but then I gave up and 32, I think it throws the gas out because it's winter. What is your rating? I kiss and put it on my head if I see 90km in the first light. Now it changes between 27-33 when burning 19 cranes "Don't
08.05.2020 16:17 # 6
They did 35 I guess I did not look at the degree exactly, but now it is going to the gas earlier, let's see what the warehouse is going to show, but if it divides it again, I will adjust it to the durutor degree ..
08.05.2020 16:17 # 7
assat76
[QUOTE = htasay] 35 I guess I did not look at the degree exactly, but now it is going to the gas earlier, let's see what the warehouse is going to show the result, but if it divides it again, it will be like the durutor degree .. [/ QUOTE]
35 Well, I don't think it will burn better if it passes to the gas early. I guess the car burned a lot since I made it at 25 degrees. It means it was kicking a little in the first passes, so it was throwing raw gas until 40 degrees. Let's look at the result.
08.05.2020 16:17 # 8
hozer33
307 lpg + automatic maintenance new output all filters + engine oil change 32lt was going 270 km now it started to go 240 km, I don't understand what's going on, friends who have advice.
08.05.2020 16:17 # 9
nbol
Book LPG, I highly recommend you to make AFR adjustment if my teacher or anyone who understands AFR (LPG path adjustment) in your location. I also have 307 1.6 XT automatic. With 35LT LPG, I never fell below 300 km in the city.
