fuel gauge problem
08.05.2020 14:51 # 1
serkan2457
hello my name serkan I joined you last week 1 week ago 2004 bought 206 xt hdi when i bought the vehicle there was a diesel light when i got a little red light, i immediately got 20 tl diesel, including the red line 3 lines burned 55 km went the red line with 2.5 lines and so on I did not understand why it did so, and the light started to light up before it came to the red line.
teşekküler
let's 2010-07-22 08:07:15
08.05.2020 14:51 # 2
deniz_206
There are 3 red lines from above, when it goes down to the first one, the light will come on but it will not be finished.
08.05.2020 14:51 # 3
shamed
You should buy gasoline when it comes to the first line. As far as I know, the general problem of pugs is the gas indicator.
08.05.2020 14:51 # 4
serkan2457
Well, before the red line comes 1 line before the light comes to the red line, it wouldn't be a problem if I took it.
08.05.2020 14:51 # 5
GokhaN
[QUOTE = serkan2457] Well, 1 line before I come to the red line, when the light comes to the red line, it is okay to stay on the road.
Do not wait there as much as possible, do not take the dirty diesel in the car.
08.05.2020 14:51 # 6
serkan2457
I understand, thank you. I don't know what you burned the tank before it was full.
08.05.2020 14:51 # 7
tuncaykan
Friends I have 206 Sw x-line, I had to do it after the light went on.
08.05.2020 14:51 # 8
muratgulen07
Be careful not to burn the red in diesel vehicles. From the diesel pump, the master in the service said exactly the same that day I will not burn.
08.05.2020 14:51 # 9
okankrgz
When the light is on, it should be forced to force too much. It can lead to pump failure.
08.05.2020 14:51 # 10
alp34
Maybe you may have a problem in the float, but the diolarki is not at work, the light goes on in the company. Fuel oil does not lift the float. 3 lines are lifted in your normal vehicle. In fact, you do not have a malfunction like float. Just think that you are buying only a little diesel. Your tank is 60 liters.
08.05.2020 14:51 # 11
striker55
in my car peugeot 206 gasoline ... the other day there was a pump failure in me ... when I called the service, it is likely to be dirty gasoline, so I suggest you not to use it with very little gasoline ... because I am making the mistake of not wanting to see the needle at zero until it fails but I do not do it anymore. ..
