fuel gauge problem
08.05.2020 17:02 # 1
ibrahim51
friends took fuel from my car the other day, although i bought 190 pounds of diesel, the indicator remained at 4/3 what is the reason? I would appreciate if you have help or have any information.
08.05.2020 17:02 # 2
Serkan
I had overfilled in his biker, the pump filled it up until the fuel was overflowing from the tank's mouth, the indicator did not rise 50-100 km, I looked, did not go to service, I removed the float and moved it manually, then I did not put fuel when the pump was thrown.
08.05.2020 17:02 # 3
35_gti_35
Fuel indicators of the 206's are problematic, which is chronic "Smile"
08.05.2020 17:02 # 4
ibrahim51
what should we do?
08.05.2020 17:02 # 5
35_gti_35
take it to a solid electrician who is probably a buoy
08.05.2020 17:02 # 6
ades23
I don't need to take it to my teacher, I came to me, I made the full filling, the same thing happened to me. I used it for a while.
08.05.2020 17:02 # 7
samet2461
Even though my warehouse was full, it looked 3/4, went to the service, said it would be coded, and I did it. There is no problem at the moment. They did it in half a sat.
08.05.2020 17:02 # 8
feline
teacher, you have 2 options & nbsp;
you will go to the 1st service and make the tank float calibration ignorant ignorant don't talk & nbsp;
golden rule every time you put fuel, you will not put under 10 liters of fuel
i print my mold this friend put fuel under 50 liters before putting that diesel and float adjustment broke ....
then 190 tl grandfather did not show the correct setting & nbsp;
feline 2012-10-03 12:40:49
