Fuel gauge
08.05.2020 19:52 # 1
omera
Hello friends
I bought gasoline 3 days ago, I filled the tank, but I made a total of 120 km, the indicator still stands full. I think it's stuck. falls when I turn off the ignition. I wonder if his float is broken.
Is there such a situation? what can we do
08.05.2020 19:53 # 2
ersin61
Come on a little more, don't worry, don't worry ..
08.05.2020 19:53 # 3
OguzhanKucuk61
I bought 20 lira gasoline very close to the end, the hand did not move. I put 30 more and looked again, no movement. Anyway we said we went. Then I got bored and bought 20 more from another station. At last I said high Bi 50 more but that Time has stood as much as it should be. Then I did a little research on this subject, I read something like it does not affect the needle when taken under a certain liter
08.05.2020 19:53 # 4
talip206
[QUOTE = OguzhanKucuk61] I bought 20 lira gasoline very close to completion, the hand did not move. I put 30 more and looked again, no movement. Anyway we said we went. Then I got bored and bought 20 more from another station. At last I said high Bi 50 more but that Time has stood as much as it should be. Then I did a little research about this subject, I read something like it does not affect the needle when it gets under a certain liter [/ QUOTE]
Fuel taken under 7 liters does not move the individual.
If you have traveled the 120 km road without getting caught in traffic, the needle will not drop because you have gone about 10 percent of the average fuel. If you go a little further, it is likely that Samandıra is stuck and will recover when you refuel. talip206 2016-06-26 04:05:41
