Fuel gauge
08.05.2020 17:50 # 1
efesbright
friends have been happening to me for the second time in the last month. I am amazed,
the fuel needle is showing below 0 when I get into the car and it does not exceed 0 when I run it. but it is increasing. fuel amount 25 lira fuel at work or when the light is on. & nbsp; Then, after making some roads, when I restart the car, it points towards the needle.
Do you think the fuel gauge is faulty or something from the heat?
08.05.2020 17:50 # 2
mtn24
I have a similar problem with my car too. The fuel gauge is decreasing even though I go in LPG. It even shows it's over gasoline. But the next day it shows half a tank of gas correctly. and it is difficult to fix. I don't know how accurate it is. I need to show it to other masters
08.05.2020 17:50 # 3
efesbright
on the trip computer, it shows the distance to be traveled correctly, but the fuel gauge is below 0, I think it will be like minibuses.
08.05.2020 17:50 # 4
demir306
The gas sensor is directly connected to the injectors because it is perceived as using gas when driving in the car. a normal situation brc sells a separate piece of it for you if you are around 100 lira, you can have it installed. There is no malfunction in the vehicle.
08.05.2020 17:50 # 5
elsoberano
[QUOTE = mtn24] I have a similar problem with my car too.I have a fuel indicator, even though I go at lpg. It shows that it is over gasoline. But the next day it shows half tank gas correctly.
asked the master, He said there was a problem with the brain of the vehicle and it was difficult to fix. I don't know how accurate it is. Even if & nbsp; .lpg goes, even if it goes on gasoline & nbsp; the needle falls. If the gas is above the half tank, the needle is replaced by the needle. Your master shook it. If you are very uncomfortable, a module is installed in the & nbsp; lpg service, it keeps your warehouse where it should be 100 TL, or there is a py pass button made by friends in the forum. .
08.05.2020 17:50 # 6
Aziz
I do not know exactly, but most of the pejos give the indicator to the indicator, I think there is no float :) it is finished even if there is fuel in it. I saw that it is being done, or the battery + pole was removed and it was recovering by waiting for 10 minutes :)
interesting :)
08.05.2020 17:50 # 7
mtn24
Exactly, according to the km.
08.05.2020 17:50 # 8
efesbright
friends still haven't found a solution to this problem, it definitely happens to others. I explain the problem again :) especially hot weather. the vehicle is waiting under the heat all day. When I get into the car like 5, it happens that the fuel needle is stuck below 0. It doesn't matter how much fuel is in it :) When you stop and run again for a while after the road goes, the needle comes right.
why this car's fuel needle deflects when it waits in heat, it doesn't show the amount of fuel & nbsp; :) the problem is exactly that :)
08.05.2020 17:50 # 9
OguzhanKucuk61
It's not exactly relevant, but I have a question. Saint friend said that the indicators provide information from the tire turn. The speedometer of the vehicle shows 90 while it shows 85 when I measure it with GPS. In this case, there is a deviation of more than 5%. Does this affect the vehicle's km counter? So when I travel 1000 km like 1050 writers ?? As my teacher said, the vehicle both writes more km and shows more speed. My tires are around 2-3% smaller than they should be. Could this have an effect? OguzhanKucuk61 2016-09-21 19:57:32
08.05.2020 17:50 # 10
talip206
[QUOTE = OguzhanKucuk61] Not exactly related to the subject but I have a question. Saint friend said that the indicators provide information from the tire turn. The speedometer of the vehicle shows 90 while it shows 85 when I measure it with GPS. In this case, there is a deviation of more than 5%. Does this affect the vehicle's km counter? So when I travel 1000 km like 1050 writers ?? As my teacher said, the vehicle both writes more km and shows more speed. My tires are around 2-3% smaller than they should be. Could this have an effect? [/ QUOTE]
If the tire size is different, this shows the speed differently. You can still write the km overwriting event with navigation. deviation probably occurs because the vehicle makes the calculation on the wheel. Map the two places on the map, reset the km and compare. or roadside signage becomes km related to the calculation. you can follow it from there. I compare as I come across
08.05.2020 17:50 # 11
OguzhanKucuk61
Let me try what you say, hodja. Let me take a measurement on my way to and from Maçka to be called a long way. So is there a way to fix the deflection caused by the small tires? Like Calibrating the tire on top?
08.05.2020 17:50 # 12
OguzhanKucuk61
I tried it on a 10 km route today. While the GPS was typing 10 km, the indicator of the vehicle was showing 10.2 km. This means that when I go 100 km, it says 102 km. There is a deviation of 2%.
08.05.2020 17:50 # 13
alierdal0335
The same situation was feverish in me.
