Fuel consumption is excessive when the air conditioner is running?
08.05.2020 19:21 # 1
rebel_43
friends 206 I have a car with a 1.4 lpg model 2001. My car is normally a long-lasting vehicle.It is 30-32 krs according to the usage in the city. Is it a problem or is it related to the lpg brain, or is this a problem ???
08.05.2020 19:21 # 2
Efe-Pojo
According to the numbers you say, there is an increase of almost 50 percent. but it was unlikely that the air conditioner would increase this much. traction drops a lot and you use a lot of gas to cover the loss? As a result, the air conditioner gets its power from the engine, but it burns almost the same when it is not pressed too hard. So at least I experienced it because I'm not a fan of using air conditioners for health.
08.05.2020 19:21 # 3
MDRNN17
Air conditioning does not make this much increase. If you are burning 30 cents, the air conditioner turns on 35 cents, I think.
08.05.2020 19:21 # 4
_ali_
In my car with the same engine and atiker lpg, 9lt without air conditioning burns 10lt lpg with air conditioning, and in the heat of Antalya, the air conditioner works like crazy. Your values are not normal, have the engine serviced.
08.05.2020 19:21 # 5
tsufrankwoli
Make the air conditioner radiator clean.
