Fuel consumption in the winter of 307 sw
08.05.2020 16:33 # 1
fordconnect
friends, I had my air filter spark plugs and general maintenance done on my car.
20 TL with 70 km & nbsp; & nbsp; - & nbsp; & nbsp; 0.285 tl per km & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; [lpg 2.2 tl / LT from & nbsp; urban]
12.9 liters of consumption per 100 km
is not a bit too much for you. Should I have a look at the gas setting of my vehicle
& nbsp;
& nbsp;
& nbsp;
& nbsp;
& nbsp;
& nbsp;
307 sw & nbsp; 2005
lavato lpg -110 hp 1.6
08.05.2020 16:33 # 2
yavuz25
In cold, snow on ice, the car burns a lot because it goes with very little amount of the wheel it spins, and let's say 100 times & nbsp; a wheel bumps 250 times on ice in the snow where you go, and as a result the fuel will increase. You have already done your best. If you take a correct measurement for the summer, you will get healthy information. "Wink"
08.05.2020 16:33 # 3
narkotik71
2003 sw & nbsp; 307 is the same in my vehicle, & nbsp; burns 0,285 _0,295tl per km. the weather is cold.
08.05.2020 16:33 # 4
harmus
My vehicle is gasoline, I don't have LPG. In the weather between -1 and +3 this past weekend, intercity lit 7.1 liters / 100 km. During the period when I used 1620 km (November-December-January) completely in the city, the average consumption burned 8.2 Lt / 100Km. It seemed good to me despite the cold weather.
Note: As I wrote before, Boron additive was used in oil change and it started to consume fuel significantly less.
08.05.2020 16:33 # 5
yavuz25
If the maintenance is complete, it is the reason I call it entirely. This situation may vary depending on the way you drive. "Smile"
08.05.2020 16:33 # 6
bestfear
Consumption seemed normal ... & nbsp; Mine was burning between 0.22-0.25 before winter ... I didn't measure it now but it was 0.28 or so ...
08.05.2020 16:33 # 7
kuantum
2006 I have 307 SW too. Normally how many cents would be normal for this vehicle to burn within km of Istanbul city? and outside the city?
08.05.2020 16:33 # 8
metato
I am from Ankara. I get lpg from 2,34tl liters. I burn 0.275tl.
08.05.2020 16:33 # 9
turbulans
I got it last week, I got the lpg yi.brc brand.de store full.150 km went and reloaded from the same pump.
08.05.2020 16:33 # 10
albayman
I climbed uphill on stable village roads in the mountainous geography of the mugla, and I made 110 km with 13 liters & nbsp; (30 lira) lpg (inter-city mixed). 27.27 pounds. our values are close to each other.
